    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Race not syncing problem
    Scheduled Pinned Locked Moved Suunto Race
    sync
    9 Posts 5 Posters 2.5k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SouniS Offline
      Souni
      Hi,
      I just recorded activity simultaneously with Race and Ambit3 to compare recordings. However when I first synced activity with Ambit and then with Race it won’t sync activity from the Race. Is this because both activities have about three same start time so it thinks it’s already synced? Can I fix this somehow?
      • Jouni
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Souni
        @Jouni-Sonninen said in Suunto Race not syncing problem:
        It depends on what do you mean for “fix it”
        You very probably can’t sync both activiites, if you want to sync the Race one, delete the activity and it should (maybe) sync race.
        Otherwise you can try uninstall reinstall after deleting the activity to force re-sync.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.8.9 beta
        • TieutieuT Offline
          Tieutieu Platinum Member
          @Jouni-Sonninen : When you say sync : in the same app ? I guess you did, but did you switched from one watch to the other in the app to get the race synchronized ?
          If you did, instead of deleting your activity, I would first try to unpair both watches, delete connexions in the watches and in phone, and pair the race again. Then try sync.
          Suunto’s devices at home :
          Vertical titanium solar
          Suunto Race S
          S9pp titanium sand
          Suunto Wing & Spark
          S9B titanium Ambassador edition, A3P, X6
          • sartoricS Offline
            sartoric Moderator @Tieutieu
            @Tieutieu
            yep, right
            SVTS - 2.50.28
            SouniS 2 Replies Last reply Reply Quote 0
            • SouniS Offline
              Souni @sartoric
              Thanks for the answers. I did switch from one watch to the other in the app to get the race synchronized. I could try the sync with another phone+app to see if I get it synced then. I will contact also the support if there is some way for them to activate sync again.
              isaziI 1 Reply Last reply Reply Quote 0
              • SouniS Offline
                Souni @sartoric
                @sartoric & @Tieutieu thanks for the help.
                Pairing the Race with another phone+app did the trick and it synced the activity from the Race 👍
                • isaziI Offline
                  isazi Moderator @Souni
                  @Jouni-Sonninen if the app (on the same device) sees the same activity (starting at the same time) from another watch it doesn’t sync it. If you start the two watches few seconds from each other you don’t have this issue.
                  Blog: isazi's home
                  SouniS 1 Reply Last reply Reply Quote 1
                  • SouniS Offline
                    Souni @isazi
                    @isazi Thanks for the info. Good to know for the future!
                    • J Offline
                      josephblcd
                      Hi all, i have a similar problem: i decided to turn off my suunto race watch for 2 days and then turned it on to record a swim activity: this activity is visible in my logbook on my watch (as the last activity I have done) but the overall week count is still at 0h, and after many syncing operations with the app, the activity is still not uploaded. Might this be a bug? …
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
