    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Komoot : one way syncing
    Scheduled Pinned Locked Moved Suunto Race
    11 Posts 5 Posters 1.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      treizeXiii
      Hello,
      I’d like to know if it’s possible to set the sync to one way : I’dl like to make a tour on komoot and import it in Suunto, but once the tour is recorded with my Suunto, I don’t want it to be sync back to komoot.
      If not possible, is it possible to import a gpx (made with komoot), and have a turn by turn navigation ? I tried today and no turn by turn navigation.
      Thank you
      Regards
      Yan
      M Mff73M 2 Replies Last reply Reply Quote 2
      • M Offline
        martin Bronze Member @treizeXiii
        @treizeXiii
        1. Not possible, sync is 2 way only
        2. I’ll let others answer, as I don’t use navigation on my watch and never even tried what you suggest…
        T 1 Reply Last reply Reply Quote 0
        • Mff73M Offline
          Mff73 @treizeXiii
          @treizeXiii
          2- i am not sure, but i think that exporting gpx from komoot and then using a third party tool to import this gpx as a route into your suunto account, should work with turn-by-turn.
          runalyze at least can do that push to suunto (manual one by one file, not any sync)
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          • T Offline
            treizeXiii @martin
            @martin
            Thank you very much.
            Could this thread be moved to feature suggestion, as a one way syncing could be great.
            @Mff73
            I selected “share with” on the gpx file created with komoot, and chose Suunto App (ios) to “share” it, and it imported it in Suunto app. But once loaded on the watch, I had no turn by turn notification.
            (I did’t use any thrid party to import/create, other than Komoot and Suunto app).
            Thank you
            Yan
            isaziI Mff73M 3 Replies Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @treizeXiii
              @treizeXiii sync is done by Komoot, so it is Komoot sending to Suunto and reading from Suunto. You could ask Komoot to implement a 1-way sync, however I doubt they would like it, as importing activities for them is important (discovering routes, heatmaps, having people share and use Komoot more).
              Blog: isazi's home
              T 1 Reply Last reply Reply Quote 1
              • T Offline
                treizeXiii @isazi
                @isazi
                Good IDea, I’ll ask. Thank you.
                In Garmin, It was possible.
                I’m just discovering the benefits and caveat f the Suunto (vs Garmin) whole system.
                Thank you.
                M 2 Replies Last reply Reply Quote 0
                • Mff73M Offline
                  Mff73 @treizeXiii
                  @treizeXiii
                  Would you share this gpx exported from Komoot?
                  Wife : S9PP
                  • AudaxjoeA Offline
                    Audaxjoe
                    I have just checked this with a file. If it syncs from Kamoot I get turn by turn directions (which I find annoying and turn off…) But if I downloaded the same ride onto my phone then upload to SA there are no turn by turn directions.
                    Suunto Vertical
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                    • M Offline
                      @treizeXiii one workaround you could try is to set your default for activities to private in Komoot, that way you can allow 2-way sync but not have your activities seen by others. That said, depending on your use case, it might clutter your Komoot account with activities…
                      As far as I’m concerned, I have different uses/friends on Komoot vs. Strava. As I use Komoot only for bike rides and have a dedicated Wahoo bike GPS, I dropped the Komoot connection from SA, and have it with the Wahoo account. It should be noted that the Wahoo/Komoot connection does not allow any setting, so it’s 2 way or off.
                      • M Offline
                        @treizeXiii said in Komoot : one way syncing:
                        I guess Garmin being far bigger than Komoot they can enforce wathever they want.
                        These days Komoot probably has a bigger user base than Suunto, so they are probably the ones dictating the sync behaviour to their advantage.
                        • Mff73M Offline
                          Mff73 @treizeXiii
                          @Mff73
                          i may think that Komoot is also not exporting (via gpx file export) their turn-by-turn information.
                          I downloaded one file from my small unlocked region 🙂 and the gpx file doesn’t contain any wpt entries.
                          Probably, as @isazi wrote, it is a business decision on their side to share with partners turnbyturn through 2 ways sync, but not to export tbt outside the app/web for any other usage.
                          Just my guess
                          Wife : S9PP
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
