    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Heart Rate Measurement stops
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    suunto 9 peak pro
    106 Posts 61 Posters 40.3k Views 65 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      loches
      Hey!
      Since about 2 weeks the heart rate measurement on my Suunto 9 Peak Pro stops every few days.
      Always realize that when I don’t get sleep/HRV Data because of the missing heart rate data… very annoying.
      Of course 24/7 heart rate measurement is on.
      Need to restart the watch every time this happens - heart rate measurement works well straight after the restart…
      Any ideas what the problem is or even better, how to fix it? 😬
      Brad_OlwinB S 3 Replies Last reply Reply Quote 4
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @loches
        @loches
        What firmware? When this happens do the LEDs stop flashing on the wrist side of the watch? Finally, is the coating over the HR sensor intact?
        Vector/T6c/Vertical 2 Ti
        Werner-Wilfried WasicsekW 1 Reply Last reply Reply Quote 0
        • Werner-Wilfried WasicsekW Offline
          Werner-Wilfried Wasicsek @Brad_Olwin
          @Brad_Olwin said in Heart Rate Measurement stops:
          The same happens to me also. I’m on the latest S9PP Firmware (2.30.38) and the coating is intact. It happens at night and I notice it as the sleep is detected only until the HR measurments stops (usualy the sleep detection is very good) and yes, the LEDs stops working, nothing flashes anymore. After a soft reset everything works again for about a week. I also sent the logs to Suunto if that helps…
          • B Offline
            Bouli
            Hello,
            same for me ! … I’m on last firmware (2.30.38) too… and never appear with the previous Firmware.
            sometimes (every weeks ?) Leds stops during the night and soft reset is necessary…
            Thanks for help
            • J Offline
              Janne Leppamaki Bronze Member
              This has happened for my S9PP maybe 2-3 times now with .38 FW. Softreset fixes the problem
                @loches and others, thanks for the information. I will test this on my 9PP with current field-test firmware to determine if this occurs with my unit.
                • E Offline
                  erikkooistra
                  Happend twice to me as wel in 3 weeks since purchase. HR stoppes about 4 hours after measuring sleep. After a soft reset it works again.
                  pilleusP 1 Reply Last reply Reply Quote 0
                  • pilleusP Offline
                    pilleus @erikkooistra
                    @erikkooistra said in Heart Rate Measurement stops:
                    For me it happened twice within the last 7 days. After 4 hours of measuring sleep.
                    Now the watch will begin its return journey … 🤙
                    https://www.instagram.com/moves.are.life/
                    Suunto Vertical Black Lime
                    Suunto 9 Peak Pro Black
                    Suunto Spartan Ultra Stealth Titanium
                    • M Offline
                      Matúš Bronze Member
                      Hi all,
                      same here!😑😑
                      Usually it happens to me twice a week: I wake up and HR sensor green light is not working at all, so I need to soft reset the watch to reinitialise the sensor.
                      It’s really really annoying…
                      @Brad_Olwin, do you have updates on this issue?
                      Suunto 9 Peak Pro Ti Slate
                      Suunto Spartan Sport
                      #swatt
                      • thailonT Offline
                        thailon Bronze Member
                        Same for me. I have to soft reset every 3 days 😞 I think it was pointed somewhere in this forum the issue is related to last firmware bug (I see my green light always flashing). It drains battery a lot.
                        T3c, Quest, Ambit3 Peak, 9PP, Vertical
                        M 1 Reply Last reply Reply Quote 1
                        • M Offline
                          Matúš Bronze Member @thailon
                          @thailon said in Heart Rate Measurement stops:
                          This behaviour is the opposite of mine, i.e., the green light is like turned off, so it does not flash at all. At least, my battery is not draining…😓
                          #swatt
                          thailonT 1 Reply Last reply Reply Quote 0
                          • thailonT Offline
                            thailon Bronze Member @Matúš
                            @Matúš flashing all day ends up being dark after some time in my case 😞 If I would not reset, it would be not flashing.
                            • A Offline
                              Ariel
                              Hello! Sorry for my mistakes with the language.
                              Since January 2024, my Suunto 9 peak pro stops measuring heart rate at night. In the morning the LED lights are off and it doesn’t work again if I don’t turn the clock on and off. I already did soft resets and a hard reset but the problem comes back after a few days. I bought the watch in August 2023 and it started crashing in January 2024, when I updated the firmware to 2.30.38. Suunto support chat indicated that I should send it to warranty, but I live in Argentina and we do not have Suunto service here.
                              Can anyone share experience? Thank you!
                              M 1 Reply Last reply Reply Quote 0
                              • M Offline
                                Matúš Bronze Member @Ariel
                                @Ariel, hi!
                                Same here, with as well a 9PP: I woke up and the flashing light was off, with all the consequences related to the HR, HRV, resources, etc… So, I need to soft rest the watch to restart the HR sensor.
                                This problem has happened to me mainly between December and January, about a half a dozen times; in February, not at all.
                                I do not know where the problem comes from, actually, I only soft reset the watch at that times and for now, it never happen again (🤞🤞); nothing has became know by the Suunto insiders here on the forum.
                                #swatt
                                freeheelerF M 2 Replies Last reply Reply Quote 0
                                • freeheelerF Offline
                                  freeheeler @Matúš
                                  @Matúš
                                  it’s known and reported
                                  living sideways
                                  M 1 Reply Last reply Reply Quote 3
                                  • M Offline
                                    Matúš Bronze Member @freeheeler
                                    @freeheeler said in Heart Rate Measurement stops:
                                    @Matúš
                                    ≠ it’s known what is going on…😜
                                    #swatt
                                    • M Offline
                                      Matúš Bronze Member @Matúš
                                      @Matúš said in Heart Rate Measurement stops:
                                      Well… It happened again last night.😢
                                      Anyway, I do not know if this could be a hint to solve this issue, but…
                                      Following my daily routine, I’m almost certain that since the last time the OHR sensor has crashed I always synchronized the watch twice a day, so once in the morning (some hours after waking up) and once in the late afternoon/evening (let’s say, around the dinner time), but definitely before night time.
                                      Yesterday, I have synchronized the watch only once in the early afternoon, so no synchronization before going to bed. Then, around midnight, the OHR sensor has crashed and this morning I did the watch soft-reset.
                                      I know that this hypothesis may sounds strange and out of context with respect to the issue, but it’s the only “anomaly” that I’m able to associate to the last OHR sensor crash.
                                      #swatt
                                      • pilleusP Offline
                                        pilleus @Matúš
                                        You may be right. I sync my S9PP every hour (this happens with the external app macrodroid to have the correct data for the sync to Google Fit) and since that procedure I never had a stop of the heart rate measurement in the night. Before it happened 2 times a week …
                                        • M Offline
                                          Matúš Bronze Member @pilleus
                                          @pilleus, “It is the same motif three times repeated. That cannot be coincidence” it is said by Poirot in a Christie’s novel…
                                          Then, waiting for the third coincidence!😝 😉
                                          #swatt
                                          • thailonT Offline
                                            @Matúš 😀😀 byť I do synch 6x per day at least and still it does happen. I found one case when it always crashes - it’s if I start to log activity (hr belt, wrist unit hr off) and finish. If I do not restart after synch, it does crashes.
                                            And if the battery is close to 0%, but happened once, so I can’t confirm association to issue.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
