    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Trying to understand how CTL, ATL and TSB are calculated in Suunto App
    Scheduled Pinned Locked Moved Suunto app - Questions & Feedback
    15 Posts 5 Posters 2.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MarioPedrazaM Offline
      MarioPedraza
      ATL is the average of your TSS over the last seven days. So, if I haven’t trained in a week or 10 days, my ATL should be zero, but it isn’t. Why? How CTL and ATL are calculated? Thanks.
      isaziI Mads Hintz-MadsenM 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @MarioPedraza
        @MarioPedraza if it isn’t, it may be a bug. CTL is the 42 days TSS average, ATL the 7 days average. TSB is yesterday’s CTL - ATL.
        Blog: isazi's home
        • isaziI isazi moved this topic from The Lounge on
        • Mads Hintz-MadsenM Offline
          Mads Hintz-Madsen Silver Members @MarioPedraza
          Hmmm, I think that the statement “ATL is the average TSS over the last seven days” may not be entirely correct. According to Training Peaks:
          TrainingPeaks calculates ATL, by default, as the exponentially weighted average of daily TSS for the past 7 days. Note that, in effect, ATL represents the training an athlete has done in the past two weeks given the nature of exponentially weighted averages.
          Formula
          ATLtoday = ATLyesterday + (TSStoday - ATLyesterday) (1/ATL time constant)
          I guess that the time constant in the above formula (which is not limited to 7 days) is set so that the weighted average is roughly equivalent to a 7 day moving average. By doing it this way, you will have a more smooth rolloff in the ATL instead of a somewhat abrupt transition to zero when you haven’t done any training for 7 days.
          Source:
          https://help.trainingpeaks.com/hc/en-us/articles/204071894-Fatigue-ATL-
          isaziI MarioPedrazaM 2 Replies Last reply Reply Quote 2
          • isaziI Offline
            isazi Moderator @Mads Hintz-Madsen
            @Mads-Hintz-Madsen good to know! Suunto is licensing these metrics from TrainingPeaks so they should work as defined by TrainingPeaks.
            Blog: isazi's home
              MarioPedraza @Mads Hintz-Madsen
              Thanks @Mads-Hintz-Madsen.
              So we cannot calculate fatigue because we do not know how to calculate the ATL time constant. Well, we have it in Suunto App, it was out of curiosity.
                MarioPedraza
                More info if interested.
                https://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/Help_me_understand_the_pmc_calculations_of_ctl_and_atl_P5530452/
                  MarioPedraza
                  Now that I have a 30-day trial on Training Peaks, I see that the TSS values ​​calculated by Suunto App is different from the TSS value of TP. So CTL, ATL and TSB do not match. In my case, I use Stryd so the TSS calculation takes power, and I have all the values ​​​​correctly configured in both places. Shouldn’t they be the same?
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @MarioPedraza
                    @MarioPedraza You need to have zones set up the same in both. My TSS values match.
                    Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                    herlasH MarioPedrazaM 2 Replies Last reply Reply Quote 0
                    • herlasH Offline
                      herlas Silver Members @Brad_Olwin
                      @Brad_Olwin this has been discussed many times before, Stryd zones are defined with upper zone 3 limit as the FTP value, Suunto on the other hand uses upper zone 4 as the FTP and this is fixed there’s no setting.
                      This makes all power-based workouts on Suunto to have TSS under-estimated.
                      Training Peaks allows to set FTP value on its own, meaning not tied to a zone.
                      I’ve been using TP TSS scores and updating my Suunto workout TSS for almost the last 3 years that I’ve using Stryd to have same realistic values. Tendencies will be similar when not doing so but numbers will not be close to what they are.
                      Hope this helps @MarioPedraza
                      FYI https://forum.suunto.com/topic/6945/running-tss-power-based-need-option-to-set-ftp?_=1706106190848
                      SRS Ti
                      SRun (primarily road runner so testing SRun is a must ;))
                      A3P (drill mode for pool swimming 🤦🤷)
                      Galaxy Z Flip 3 / Galaxy S24+
                      MarioPedrazaM Brad_OlwinB 2 Replies Last reply Reply Quote 1
                        MarioPedraza @Brad_Olwin
                        @Brad_Olwin That’s how I set it, but the values ​​are different in my case. Who knows…
                          MarioPedraza @herlas
                          @herlas Thanks.
                            Brad_Olwin Moderator @herlas
                            @herlas OP did not say power. I don’t use power, mostly HR.
                            herlasH 1 Reply Last reply Reply Quote 0
                            • herlasH Offline
                              @Brad_Olwin it’s there but no worries 🙂
                              SRS Ti
                                @herlas OP quote in first post
                                MarioPedrazaM 1 Reply Last reply Reply Quote 0
                                  @Brad_Olwin Ok
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
