    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Treadmill - SPEED AND DISTANCE BY WALK WITH GPS CALIBRATION
    Scheduled Pinned Locked Moved Suunto Race
    19 Posts 10 Posters 2.7k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • laufbursche7L Offline
      laufbursche7
      Hello everyone,
      I’m really shocked at the massive difference in distance between the treadmill and the Suunto Race (yes, I know you can edit the distance afterwards).
      My Polar was more accurate and I was able to calibrate it.
      This is described here: https://support.polar.com/en/speed-and-distance-from-the-wrist-with-gps-calibration
      How GPS calibration works
      To enhance the accuracy of speed and distance measured from the wrist, the watch uses GPS offset calibration. The watch compares speed values measured with the accelerometer with values measured with GPS, and calculates momentary speed calibration offset values based on the difference.
      Calibration requirements:
      Sport profile used must be running or walking type (listed below)
      Steady pace speed is at least 7 km/h for at least 15 minutes
      The terrain you run on is flat enough
      Is there a similar function for the Suunto?
      I have not yet found a setting option in the app or on the watch.
      Thanks for your tips
      KetoohsK EgikaE 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        No need for uppercase 😉
        SVTS - 2.48.16
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Samsung A33 2022 - Android 15 - One UI 7.0
        Suunto App Android 6.6.5 beta
        Suunto App IOs 3.7.1 (21291) beta on MBP M1 Max
        • KetoohsK Offline
          Ketoohs Silver Members @laufbursche7
          @laufbursche7 Yes, the function is called Stryd 😁
          I was ranting about the accuracy from the 9 Peak on (actually if I remember correctly the Spartan had much better accuracy), and then just gave in on BlackFriday and bought a Stryd. Now my pace is a few seconds per km off from the treadmill.
          There is also other hardware RUNN sensor… but no SW option on the watch.
          Karoo3 (2024)
          Vertical allBlack (2023)
          9 Peak Black (2022)
          Spartan WHR Black (2017)
          Ambit 2 Black (2013)
          • EgikaE Online
            Egika Platinum Member @laufbursche7
            @laufbursche7 yes, for running and walking this is active in the background for Suunto.
            After completing the first activity that has enough data, you will get a notification “running calibrated” or “walking calibrated”.
            AFAIK this will update continuously afterwards and the calibration be used for treadmill runs or other running/walking activities without GPS
            t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
            laufbursche7L 1 Reply Last reply Reply Quote 0
              laufbursche7 @Egika
              @Egika said in Treadmill - SPEED AND DISTANCE BY WALK WITH GPS CALIBRATION:
              Thanks!
              Oke then the notification appears on the watch?
              This is my fourth treadmill session for now.
              • EgikaE Online
                @laufbursche7 it will only calibrate when running outdoors with GPS on.
                Notification will only happen after the first successful outdoor GPS-based run.
                Treadmill will then be able to use this calibration data.
                Still, you can adjust the treadmill distance in the watch right after the workout.
                  laufbursche7 @Egika
                  That doesn’t make any sense.
                  I want to calibrate the treadmill units.
                  Outside, the distances fit so far. There were minimal differences of a few meters between the Suunto Race and my old Vantage M.
                  I’m only concerned about the massive deviations without GPS on the treadmill.
                  Mff73M EgikaE 2 Replies Last reply Reply Quote 0
                  • Mff73M Offline
                    Mff73 @laufbursche7
                    @laufbursche7
                    as far as i understand, the watch will learn from your outdoor gps activities (calibrate) your way of running (step lenght, pace, etc…) and then (once calibrated), your watch should be more precise while running on the threadmill using threadmill sportsmode (without GPS)
                    Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                    Suunto Vertical all black
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android 13, Galaxy S205G
                    • EgikaE Online
                      @laufbursche7 it does make sense very much. And it works as described in your initial post.
                      let me try to rephrase in case of misunderstanding:
                      • On the treadmill, there is no speed information from GPS signals.
                      • the watch tries to deduct your speed from your arm movement (frequency and amplitude etc).
                      • arm movement dring running is highly individual
                      • that is the reason why a calibration is needed
                      • the calibration will take place automatically during a run with proper GPS, where the watch reads GPS speed and wrist movement.
                      • this data is then used on activities without GPS
                      Speed= Calibration_Factor * arm_movement
                      To find the Calibration_Factor you need to know both Speed (from GPS) and arm_movement (during activity)
                      If you have it you can derive the speed according to above formula.
                      1 Reply Last reply Reply Quote 3
                      • W Offline
                        wakarimasen Gold Members
                        Not sure if it helps, but I ran on a treadmill yesterday evening for the first time since the latest S9PP firmware update. After finishing, I saw the option to edit the distance (in the watch) to match the treadmill, which I did. After doing this, I saw a message: something like ‘treadmill calibrated.’
                        Suunto Race Titanium
                        Suunto Ambit3 Peak
                        Polar H10
                        Polar OH1
                          laufbursche7 @wakarimasen
                          @wakarimasen
                          Oh… great News…than I waiting for this message
                          Arie RahmadiA 1 Reply Last reply Reply Quote 0
                          • Arie RahmadiA Offline
                            Arie Rahmadi @laufbursche7
                            @laufbursche7 Hi, did you get the message about the treadmill calibrated? Actually I’m using race S, but it seems that the distance also not accurate everytime.
                            Weird thing is, at the low speed (when you walk on treadmill) 4-5km/h, the watch record longer distance than the treadmill, It become more accurate at high speed >7.5km/h.
                            However, when I’m running at pace 6, the watch only shows pace 7.
                            • EgikaE Online
                              Egika Platinum Member @Arie Rahmadi
                              @Arie-Rahmadi the calibration message has been removed in current firmware versions.
                              Still the calibration is taking place in the background.
                                Arie Rahmadi @Egika
                                @Egika the calibration will be depend on outdoor running only? or will it done after several treadmill session?
                                Danny polegD 1 Reply Last reply Reply Quote 0
                                • Danny polegD Offline
                                  Danny poleg Silver Members @Arie Rahmadi
                                  @Arie-Rahmadi
                                  After the last update - as soon as you finish running on the treadmill you can change the distance according to what appears on the treadmill and then all the data is reset accordingly
                                  It is important to emphasize that the change in the clock must be done before pressing - finish
                                  Arie RahmadiA 1 Reply Last reply Reply Quote 1
                                    Arie Rahmadi @Danny poleg
                                    @Danny-poleg pardon me, what do you mean by “all the data reset accordingly”. Is it only the calculation of avg pace or including the avg pace per split? Because in my experience it just the first one, the avg pace per split did not change.
                                    Example: I run on speed 6km/h for 1 hour, the treadmill calculate distance as 6km, while the watch record 8km. If I update the distance in the watch as 6km, indeed the avg pace in the general information change, but the avg pace in every split still the same based on 8km.
                                      @Arie-Rahmadi You are right, only the general figure, the split will not change
                                      • A Offline
                                        Albon
                                        Suunto still have not fixed the calibration, for me it’s awful. I’m doing 8:30 pace and the watch register 12:30 pace. I calibrate every time after and I also run outside.
                                        On top of this, after you calibrate, the app won’t adjust the mile splits…All this worked very well in my old Coros watch. I hope Suunto fix this bug!
                                        isaziI 1 Reply Last reply Reply Quote 0
                                        • isaziI Offline
                                          isazi Moderator @Albon
                                          @Albon running outside is not used anymore for calibration
                                          Blog: isazi's home
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
