    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    What Ttype of Heart Rate Belt
    Scheduled Pinned Locked Moved Suunto Race
    14 Posts 6 Posters 4.1k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      MassimoX73
      Hi, I’m a new user, I’ve bought a Sunto Race about 7 days ago, but I need to use a Heart Rate Belt for running, I can use any type of belt? I’d like to buy a Polar H10 Belt, is it compatible with suunto Race?
      Thank you.
      Bogdan1921B Brad_OlwinB mikekoski490M 3 Replies Last reply Reply Quote 0
      • Bogdan1921B Online
        Bogdan1921 Silver Members Bronze Member @MassimoX73
        @MassimoX73
        Yes, Polar H10 it’s compatible without any issue, easy to pair and works perfect.
        Suunto Race
        Polar H10
        Iphone 14 Pro
        Suunto 9 Baro [sold]
        M 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @MassimoX73
          @MassimoX73 It is compatible but only the Suunto HR belt will provide HR memory for syncing back to the watch. If you use it for swimming this is critical. Also, for sports where wearing a watch in inconvenient, you can start an activity with the watch and belt, put the watch on the table or in a locker, do the activity and stop the activity with the watch. All HR data will sync back to the watch. No other brand will have this memory function with a Suunto watch.
          Vector/T6c/Vertical 2 Ti
          M 1 Reply Last reply Reply Quote 1
          • mikekoski490M Offline
            mikekoski490 Bronze Member @MassimoX73
            @MassimoX73 I have both Suunto Smart and Polar H10, but prefer the Polar.
            The Polar strap is a bit better made, and stays in place better because it spaces out little silicon soft dots to stop it from sliding.
            Also, the Polar H10 has both an ANT+ channel and 2 Bluetooth. I prefer the ANT+ for my bike computer as drains battery slower, and can pair my Suunto same time to the same belt as well.
            Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
            Current: Suunto Race Ti
            Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
            Suunto App running on Google Pixel 8/Android 14
            • M Offline
              MassimoX73 @Brad_Olwin
              @Brad_Olwin Thank you, but I want to know, if I connect a belt to the watch and I start activity on the watch the Heart Rate I see on it read from belt?
              • M Offline
                MassimoX73 @Bogdan1921
                @Bogdan1921 tnks!
                • M Offline
                  MassimoX73 @mikekoski490
                  @mikekoski490 thank you, I want to know: if I connect a belt to my watch and I start a new run activity, the HR I see on the watch display came from the belt??
                  ? Brad_OlwinB 2 Replies Last reply Reply Quote 0
                  • ? Offline
                    A Former User @MassimoX73
                    @MassimoX73 Yes, if you pair a HR belt and whenever you put it on and start an activity, you will see a little belt icon next to your HR on the activity start screen (right before starting the activity). If that was the question.
                    ppresingP M 2 Replies Last reply Reply Quote 0
                    • ppresingP Offline
                      ppresing Bronze Member @Guest
                      @tomasbartko said in What Ttype of Heart Rate Belt:
                      Yes. If Ext HR is paired, priority is on Ext HR, otherwise Race uses HR from the wrist. But mind. If you start activity, you can’t switch between Ext Hr and Wrist HR. The type of HR transmition stays the same during the activity. If You want to f.e. switch from Ext to Wrist, you should finish current and start a new activity.
                      • M Offline
                        MassimoX73 @ppresing
                        @ppresing Perfect!! Thank you so much!!
                        mikekoski490M 1 Reply Last reply Reply Quote 0
                        • M Offline
                          MassimoX73 @Guest
                          @tomasbartko TNKS!!!
                            @MassimoX73 Also if it helps, for my priority activities (trail running/running) where I want to always ensure its picking up the HRM belt over the OHR, I turn off OHR for those activities in the sports profile settings.
                            • M Offline
                              @mikekoski490 OK TNKS!
                                @MassimoX73 yes from any belt the HR on the watch during an exercise defaults to belt first.
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
