    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto vertical ascent/ descent totally incorrect
    Scheduled Pinned Locked Moved Suunto Vertical
    70 Posts 22 Posters 19.3k Views 27 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      deldrago
      Hi everyone ! I’ve been recently hiking with my suunto vertical and this is what happening: I start the hike at 1.400m and reach the top of the mountain at 2.150m. The altimeter during the hike is perfect. The graphic on the app is also very accurate. But the ascent/descent values are totally wrong… it says 2.100 m ascent when the correct number is arount 750m. What is happening ? This is the second time.
      EgikaE gontzalffG 2 Replies Last reply Reply Quote 0
      • EgikaE Online
        Egika Platinum Member @deldrago
        @deldrago
        usual reasons:
        • windy outside and watch exposed to wind
        • watch under clothes that “pump” air into the sensor from movement
        • rain/snow on sensor
        • gontzalffG Offline
          gontzalff @deldrago
          @deldrago me sucede exactamente lo mismo.
          • J Offline
            JayLaz
            I have the same problem every time I use the watch since the last update. My ascent and descent values are massively exaggerated, even when going uphill my descent value increases!! This did not happen with my Spartan Ultra and makes the Vertical inaccurate for navigation. Anyone else experiencing the same and know how to fix?
            Mff73M freeheelerF 2 Replies Last reply Reply Quote 0
            • Mff73M Offline
              Mff73 @JayLaz
              @JayLaz
              did you read the post of Egika, just two posts above ?
              little more detailed here https://forum.suunto.com/post/135021
              you can also add another possible root cause : dirty baro sensor.
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              • freeheelerF Offline
                freeheeler @JayLaz
                @JayLaz
                as @Mff73 says 👌
                what usually helps us to guess potential root causes are screenshots from the alti graph or even better a link to your publicly shared activity (if it doesn’t violate your privacy!)
                does it happen randomly or with every activity?
                we maybe can exclude some root causes with more info. in worst case, we will recommend to get in touch with support.
                living sideways
                J 1 Reply Last reply Reply Quote 0
                • J Offline
                  JayLaz @freeheeler
                  It’s been happening since the last update. Attached is a link to the data
                  https://maps.suunto.com/move/jasonpreston190/65be3e08f49857756c21e12e
                  freeheelerF 1 Reply Last reply Reply Quote 0
                    freeheeler @JayLaz
                    @JayLaz
                    the graph shows several ups and downs that do not match the topography of your recording. they are very small, but they might sum up to 50% more total ascent.
                    it looks like it was windy during the activity with 8m/s and maybe some gusts even faster?
                    is your observation the same on a windless day or is the recording more precise?
                    living sideways
                    • J Offline
                      JayLaz
                      It was a windy day but that’s very common in the UK and it is an outdoor watch after all so it should be accurate. I think I had gained 300m of descent even on the long steady uphill to my highest point!
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @JayLaz
                        @JayLaz which wrist do you wear the watch on? It might help to switch. If I recall, the baro sensor is on the side. The newer watches have a different placement that prevents nearly all wind interference in my testing.
                        Vector/T6c/Vertical 2 Ti
                        M 1 Reply Last reply Reply Quote 0
                        • M Offline
                          maszop Bronze Member @Brad_Olwin
                          I will write about my experiences.
                          Since Suunto 9 Peak/Pro/Vertical (possibly due to a change in the position of the pressure sensor or too aggressive measurements), always in relatively windy conditions the measurement of the sum of elevation gains is completely overestimated, from 30% to several hundred percent.
                          As you walk, you can see the altitude reading fluctuating every few seconds, which is where the erroneous results come from.
                          In older watches, Ambit, Traverse and 9Baro, the altitude indication at individual points was less accurate, but such problems with the sum of elevations were much less common.
                          In the mountains, the sum of elevation gain is one of the most important data and the statistics from newer watches are partially useless.
                            Brad_Olwin Moderator @maszop
                            @maszop I do not have this issue and where I ski is very windy almost always. Front Range of Rocky Mts USA. I wear my watch outside my jacket.
                            There may be something with your device. I have used the Vertical the most.
                            M 1 Reply Last reply Reply Quote 1
                            • M Offline
                              @Brad_Olwin The key word is “skiing”.
                              The problem occurs with slower activities (hiking mountaineering etc.). The altimeter shows rapid fluctuations in the altimeter, which are completely unrealistic, e.g. when climbing a mountain.
                              This applies to several watches, so it is not a defective item.
                              • E Offline
                                Elipsus Gold Members
                                Theres also the “up down” threshold that seems overly sensitive, I talked a bit about it with my father and the main trouble is that the ascent values are far, far above the actual vertical ascent, and thus not really realistic when looking at a map, its a bit of dissonance between old and new methods :
                                • “so, we’re at 600m, the peak is at 2000m, so that means that this hike is a 1400m ascent”
                                • “according to my watch its a 1800m ascent, because you have tons of very tiny downhills”
                                So that means that when your watch told you you did 700m ascent, you don’t have 700m left like you would expect when you looked at the map, but far more.
                                So the thing is skewed, and my father kindly berate a bit my results (he is an hardcore, very old school mountaineer) :
                                • Me : "Hey dad I did a nice hike today, 2000m ascent ! "
                                • Dad : “what, you mean 200m ascent right ?” 😝 😝
                                This problem is not Suunto only, but its indeed a bit frustrating
                                  @maszop I do not have issues trail running mountains either, sometimes very slow including 100 mile mountain races.
                                  T 1 Reply Last reply Reply Quote 1
                                  • T Offline
                                    The_77 Silver Members @Brad_Olwin
                                    (9PP) I’ve had a variety of elevation change issues recently, but I can accept that because of the wind being severe whilst trail running. I was ~ 800m out on Sunday last week (2.1k vs 1.3k) and 300m out on Thursday (830m vs 530m), but those were in winds I was being slapped with and severely impeded movement sometimes. Not sure any sensor position is getting around those.
                                    If I notice it more on low wind days then I’d be concerned. Always on top of layers, and not being trapped by a jacket/top flapping on it.
                                    Suunto Spartan Trainer Wrist HR / 9PP Refurb
                                    • M Offline
                                      maszop Bronze Member @The_77
                                      @The_77 In the case of Suunto 9 Baro (and older watches, and watches from G), the problem occurs rarely. Very common in newer models. So there should be room for improvement.
                                        freeheeler @maszop
                                        @maszop
                                        we’ve had different issues with the S9B that I am really really happy Suunto got rid of them
                                        living sideways
                                        • M Offline
                                          maszop Bronze Member @freeheeler
                                          @freeheeler I understand progress and new features, but breaking things that work well is unacceptable.
                                          isaziI 1 Reply Last reply Reply Quote 0
                                          • isaziI Offline
                                            isazi Moderator @maszop
                                            @maszop the Baro was not working well at all, in fact it was much worse than new watches, being not only susceptible to wind but also rain and water. And the Ambit had the hole on the bottom of the watch, getting crazy if you did sweat.
                                            Edit: not to minimize the issue, I had it today for example, 35 meters of ascent when it should have been 0, because of code yellow winds
                                            Blog: isazi's home
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
