    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Which charging cables are Race compatible?
    Scheduled Pinned Locked Moved Suunto Race
    chargingcable
    11 Posts 5 Posters 3.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Olaf GottschalkO Offline
      Olaf Gottschalk Bronze Member
      …it was only a matter of time until I forgot to pack my charging cable… 🤣
      Looking around the Internet to quickly order a replacement to my holiday location I find it rather difficult to judge which ones are compatible.
      Does a charger for Suunto 9 Peak Pro fit? It looks identical…
      Which others are “the same”?
      Thanks!
      TieutieuT 1 Reply Last reply Reply Quote 0
      • TieutieuT Offline
        Tieutieu Platinum Member @Olaf Gottschalk
        @Olaf-Gottschalk the SR charging cable is be the same for SR, SV and S9pp.
        Suunto’s devices at home :
        Vertical titanium solar
        Suunto Race S
        S9pp titanium sand
        Suunto Wing & Spark
        S9B titanium Ambassador edition, A3P, X6
        Olaf GottschalkO 1 Reply Last reply Reply Quote 2
          Olaf Gottschalk Bronze Member @Tieutieu
          @Tieutieu I ordered a Suunto 9 Peak Pro cable that looks completely identical on the pictures… 😊
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Olaf Gottschalk
            @Olaf-Gottschalk That is fine, the 9Peak cable if they still sell the old one is not compatible, the magnets were too strong. I suspect it has been replaced with the new one on Suunto but perhaps not on 3rd party sites.
            Vector/T6c/Vertical 2 Ti
            Olaf GottschalkO 1 Reply Last reply Reply Quote 0
              Olaf Gottschalk Bronze Member @Brad_Olwin
              @Brad_Olwin thanks for the info!
              Speaking of strong magnets: with the Race - what I don’t understand: the charger connect area is round and the magnets not at all strong so that you can easily rotate the watch while on the charger. But it only has connection to the charging contacts in the position where the cable goes directly out to the right.
              Inadvertently touching this setup leads to the contacts being rotated away from their needed position.
              Has this been a deliberate design?
              I come from Polar charger of the Grit X models which only snap into position in the one alignment it needs…
              How do other users here make sure nothing touches the charging Race?
                @Olaf-Gottschalk Deliberate, as I stated below magnets cannot be stronger. I agree, mine is easy to move and not charge. I still prefer this to a plug though or a clip.
                • Mff73M Offline
                  Mff73
                  Without knowing all the technical and design constraints, I would think that a “weak” magnet could have been added with “spartan like” grooves for the charger not to rotate.
                  But it is like it is.
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  1 Reply Last reply Reply Quote 5
                    @Brad_Olwin yes, but why didn’t they construct some kind of groove that prevents turning the charge pod underneath the watch?
                    • TieutieuT Offline
                      @Olaf-Gottschalk only Suunto knows !
                      As long as the Sv, sr S9pp are getting charged very quickly, I don’t really care how strong the charger olds.
                      I confess it’s a bit « annoying » to have to be careful to put it in place…but it takes 3 seconds…
                      Meantime the back of the watches is very confortable and easy to clean.
                      Suunto Race S
                      S9pp titanium sand
                      Suunto Wing & Spark
                      Olaf GottschalkO 1 Reply Last reply Reply Quote 1
                        @Tieutieu the problem is that if you have kids or animals, it’s rather awkward to find a place nobody else can reach… They could have done this much better. If I were a product designer, there’s a 0% chance I would ever design anything alike… 🤣
                        P 1 Reply Last reply Reply Quote 4
                        • P Offline
                          Peaks and Summits @Olaf Gottschalk
                          @Olaf-Gottschalk I strongly agree - while on the trail it’s simply impossible to charge through a solar panel or power bank without the charger and watch getting separated. Think it’s super strange there is no lock to keep it in place.
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
