    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Heart rate not detected
    Scheduled Pinned Locked Moved Suunto Race
    53 Posts 14 Posters 16.3k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • leafs93L Offline
      leafs93 Bronze Member
      I have had a few occasions where my heart rate suddenly cannot be detected and Watch must be reset before heart rate can be detected. Quite frustrating that there are still number of issues like this that otherwise would have made this watch a good one. Anyone else who have experienced this ?
      Brad_OlwinB L E 3 Replies Last reply Reply Quote 0
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @leafs93
        @leafs93 This should not happen. You may have a hardware issue. I would contact support.
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
        leafs93L 1 Reply Last reply Reply Quote 1
        • leafs93L Offline
          leafs93 Bronze Member @Brad_Olwin
          @Brad_Olwin thanks. I thought this is a software issue as the HR usually works well… out of the last 2 months, probably had this issue 3 times or so… will contact support. Thanks
          • herlasH Offline
            herlas Silver Members
            I have had this issue once on my SV (different watch) on the latest firmware, went for a run, I was surprised to not get HR locked icon on the screen before starting the workout, tried many things on the watch but it didn’t help until I restarted my watch.
            I haven’t had this issue again, but as @Brad_Olwin said, if you see this often contact support.
            SRS Ti
            SRun (primarily road runner so testing SRun is a must ;))
            A3P (drill mode for pool swimming 🤦🤷)
            Galaxy Z Flip 3 / Galaxy S24+
            leafs93L 1 Reply Last reply Reply Quote 0
            • leafs93L Offline
              leafs93 Bronze Member @herlas
              @herlas thanks ! Will monitor abit more and contact suunto if it happens again. I believe it could be the software update .
              Zdeněk HruškaZ 1 Reply Last reply Reply Quote 0
              • Zdeněk HruškaZ Offline
                Zdeněk Hruška Bronze Member @leafs93
                @leafs93 I am owner of Suunto 9 Peak Pro but it happened to me once as well after the latest fw upgrade. Maybe it’s not related but I just wanted to add my experience.
                1 Reply Last reply Reply Quote 5
                • L Offline
                  Luis Andés Olmedo Bronze Member @leafs93
                  @leafs93 I’ve had this issue twice in the last 3 days during normal use. The OHR sensor is not working (no led) and only reset works…
                  • E Offline
                    Elipsus Silver Members @leafs93
                    @leafs93 I did experience this issue once since the last update , the HR sensor just stopped blinking one night and didn’t restart until I rebooted the watch.
                    I sent the logs to Suunto, but since we can’t really describe the reason why we send the log I’m not sure how they manage it on their side
                    EgikaE 1 Reply Last reply Reply Quote 2
                    • EgikaE Offline
                      Egika Platinum Member @Elipsus
                      @Elipsus great you sent logs! Suunto can have a look into it, once they also receive the information about the issue that was behind the logs.
                      If you still know the date and time when you sent them, plus you tell me (in a private message) your Suunto app user name, then I can make it a ticket that will be followed.
                      t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                      1 Reply Last reply Reply Quote 3
                      • leafs93L Offline
                        leafs93 Bronze Member @Luis Andés Olmedo
                        @Luis-Andés-Olmedo just experienced my forth time today during my workout. HR not reading… I think I will have to do a factory reset to see if this issue continues
                        M 1 Reply Last reply Reply Quote 0
                        • M Offline
                          martin Bronze Member @leafs93
                          @leafs93 you should send logs ASAP after it happens.
                          You can do so from the app, at the bottom of your profile page (the user icon at the bottom right).
                          • L Offline
                            Luis Andés Olmedo Bronze Member @martin
                            It has happened to me twice more, always with the watch on the nightstand (I don’t use it to sleep). When I put it on in the morning, the optical pulse sensor does not turn on and I have to reset.
                            I just sent the logs to SUUNTO.
                            Brad_OlwinB leafs93L 2 Replies Last reply Reply Quote 0
                              Brad_Olwin Moderator @Luis Andés Olmedo
                              @Luis-Andés-Olmedo Can you PM me and provide the time you sent logs, the date (I am in the US so we are a few hours apart likely) and the email you use to log into the Suunto app. I will file a bug report.
                              • L Offline
                                Luis Andés Olmedo Bronze Member @Brad_Olwin
                                @Brad_Olwin said in Heart rate not detected:
                                Done, thank you
                                • L Offline
                                  Luis Andés Olmedo Bronze Member @Luis Andés Olmedo
                                  It happened again tonight (two nights in a row). When a I take the watch from the nightstand the OHR does not activate.
                                  I reset and sent logs again (8:33 CET)
                                    @Luis-Andés-Olmedo If you want to you could try a hard reset, you will lose accumulated data and custom sport modes.
                                    Do you have HRV turned on? Or Sleep Tracking turned on? If you are not measuring at night those should be off.
                                    • L Offline
                                      HRV and Sleep tracking are off. I wouldn’t like to do a hard reset and reconfigure everything…
                                        @Luis-Andés-Olmedo I have not received feedback yet about the bug report.
                                        • L Offline
                                          Thank you
                                          • leafs93L Offline
                                            @Luis-Andés-Olmedo exactly the same for me. Seems like the sensor will stop detecting HR if you don’t wear it continuously. Anyways I was in contact with support team as advised by someone here, sent in my watch for repair and they sent a replacement set to me. I just got it back 2 days back . So far so good, but will monitor again
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
