    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2MAX (suunto RACE)
    Scheduled Pinned Locked Moved Suunto Race
    33 Posts 13 Posters 11.0k Views 14 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S.PichiS Offline
      S.Pichi
      Hi All,
      How many time (at least ) to do workout (running , walking) to get VO2max for Suunto Race .
      i run more than 5 time ( more than 15 mn with 70% of max HR per each)
      But still cannot get the number of VO2max.
      Thanks.
      Eddy De BackerE Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • Eddy De BackerE Offline
        Eddy De Backer @S.Pichi
        @S-Pichi Same with me, 10 à 15 runs that are labeled as VO2max in SA, but don’t get an estimated VO2max and fitness age in the SR. I did another run with my SV and I did get VO2max and fitness age. I stick with the SR, too nice amoled screen. Hoping for an improvement with the update that will come soon (they say).
        Suunto Race 2 Titanium Trail
        Eddy De BackerE 1 Reply Last reply Reply Quote 0
          Eddy De Backer @Eddy De Backer
          @Dimitrios-Kanellopoulos @Brad_Olwin After the update for the SR, for which thanks, the message was added in CTL to do 1 run outside for performance and 3 runs for run estimations and acidification threshold.
          I did 3 short runs, all labeled VO2max :
          17 minutes - 1,72km - 99% in HR-zone 3 or higher
          22 minutes - 2,29km - 100% 3 or higher
          35 minutes - 3,64km - 100% 3 or higher
          CTL gives 56 for fitness - + 32 increason rate and productive training
          But still no estimated VO2max and fitness age yet.
          I did a soft reset, nothing changed.
          What now ?
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @S.Pichi
            @S-Pichi I am not sure what the requirements for the runs are. Short runs may be insufficient, it may require runs on multiple days. The VO2M works for me on this firmware. I would be a bit patient and see what happens. I would also take the VO2M values as estimates, the watch does not give me the same value I have from a lab test, the watch is always lower. I would not assume the watch can tell you your exact VO2M but can be better used to determine a trend of going up or down.
            Vector/T6c/Vertical 2 Ti
            1 Reply Last reply Reply Quote -1
            • Darryl LinD Offline
              Darryl Lin
              Yes,my Suunto Race can’t get VO2 Max.I run more 3 times a week,and the software is latest!
              fabula670F 1 Reply Last reply Reply Quote 0
              • fabula670F Offline
                fabula670 @Darryl Lin
                @Darryl-Lin
                Hi Darryl,
                mine showed the VO2max after the 3rd run (almost 55’, but it was a mix of walking/run, a la Galloway☺
                I’m on the last firmware and after the run I got a message telling me the watch was calibrated for the run.
                On the very first (long) walking I made after just bought the watch (a couple of months ago, with previous firmware) I also got the VO2max and I also got the message “watch calibrated for the walk”.
                That’s my case, hope all will be right.
                Fabio
                • gilouG Offline
                  gilou
                  Bonjour a tous,
                  récent et heureux propriétaire une race (3 semaines), j’ai une petite interrogation quant a la valeur de la vo2max. j’ai fonctionné pendant 3 ans avec une S9 baro ma Vo2max n’ayant jamais depassé 46. Avec le meme volume d’entrainement, et une bonne dizaine d’activité enregistrées, elle arrive à 51. Donc pensez vous que l’algorithme de la race est réellement différent des anciennes versions ou une autre explication…
                  • C Offline
                    CuriousIndi
                    Hello,
                    I also have a Suunto Race, so far I have 7 runs most of them with Zone 4 & 5 as well.
                    Screenshot under CTL it still says "Have at least one Outdoor Run to get Results (tranlated from German).
                    Any news on an expected range of runs and what nature these runs should be?
                    (Two oddities: I have increased resting HR to 75 to see if it improves sleep tracking performance (Answer is not really) and I’m waring the watch on the right side. )
                    A 1 Reply Last reply Reply Quote 0
                    • A Offline
                      andymsp73 @CuriousIndi
                      @CuriousIndi
                      Hi, my race is exactly the same (no vo2 max and/or fitness age), bought the watch Feb 24 and run average 20 miles/wk. Suunto have been unable to resolve the issue, they even sent me a new watch but it still says ‘run at least one run ….’ Do you need to calibrate somehow? The support from Suunto is awful!
                      surfboomerangS isaziI 2 Replies Last reply Reply Quote 0
                      • surfboomerangS Offline
                        surfboomerang @andymsp73
                        @andymsp73 Have you tried running with a HR belt? I don’t know if Suunto does count the run when HR readings are too unreliable.
                        Suunto Vertical Titanium Solar
                        OnePlus Nord 4
                        • isaziI Offline
                          isazi Moderator @andymsp73
                          @andymsp73 there is a bug on the Race that will be fixed in few weeks, at the moment you need to have a good run with external HR monitor
                          Blog: isazi's home
                          A I 2 Replies Last reply Reply Quote 1
                          • A Offline
                            andymsp73 @isazi
                            @isazi thanks for the reply, will the bug fix solve the VO2 readings then or will I need to purchase a external HR monitor as well?
                            fifi1-3013F isaziI 2 Replies Last reply Reply Quote 0
                            • A Offline
                              andymsp73 @surfboomerang
                              @surfboomerang no I haven’t, assumed the watch would work without one, what type of HR do I need ? Thanks for the reply!
                              surfboomerangS 1 Reply Last reply Reply Quote 0
                              • fifi1-3013F Offline
                                fifi1-3013 @andymsp73
                                This morning I did a competitive race (14km) with thé “polar verity sens”, it worked.
                                • isaziI Offline
                                  @andymsp73 it will fix the behavior of VO2max, so that it works also with OHR
                                  Blog: isazi's home
                                    @andymsp73 it should work with OHR (it does on my Vertical), but with previous algorithm it would skip runs with a bad HR reading. I don’t know if the new Suunto native algorithm does the same. And if this is causing your issue.
                                    So if you can get your hands on a belt, you can try.
                                    OnePlus Nord 4
                                    • A Offline
                                      @surfboomerang thanks, the watch is advertised as providing VO2 and age fitness without the need to buy a HR monitor. Hopefully the new bug fix will sort this out but I’m not expecting it to. Appreciate the advice though 👍
                                      • I Offline
                                        iwanczak @isazi
                                        @isazi Does problem was fixed? I don’t think so.
                                        I ordered Sunnto Race few months ago. Ive walked, run and no vo2max. One week ago I’ve purchased Kalenji HRB 500 monitor, connected with Race, done few running, walking and still no vo2max.
                                        Every testing runs and walks I did in 2 and 3 intensity zones. I used original Race programs, as it was adviced by Suunto customer care in other post, 2 and 3 zones more than 8 minutes, no pausing, excellent GPS conditions, as it was also adviced via Suunto customer care, and no effect.
                                        When I use Suunto Vertical vo2max appears after first, 15 minutes run, 3 zone was only 2 percent.
                                        Unfortunately, using Race i can feel China quality… 😔
                                        DesdinovaD 1 Reply Last reply Reply Quote 0
                                        • DesdinovaD Offline
                                          Desdinova Bronze Member @iwanczak
                                          @iwanczak I’ve had a lot of vo2 readings, so your hr zones may be off. Do the lactate threshold test, set your z4 boundary from that and see if it helps perhaps?
                                          DesdinovaD I 2 Replies Last reply Reply Quote 0
                                            Desdinova Bronze Member @Desdinova
                                            An example
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
