    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Swimming pool
    Scheduled Pinned Locked Moved Suunto Race
    48 Posts 23 Posters 12.9k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zen_pavelZ Offline
      zen_pavel
      Hello Community,
      I’m inspired by aesthetics of new Suunto Race and really want to buy it. One of my main activities is swimming in the local pool which is pretty crowded. I’ve tracked it by Huawei and Amazfit watches which did it accurately and reliably. But then I had to return Fenix 7 because of laps randomly missed or multiplied.
      What kind of experience do you have with Race?
      RangoR EgikaE 2 Replies Last reply Reply Quote 0
      • RangoR Offline
        Rango @zen_pavel
        @zen_pavel So far, I have used the Epix 2 Pro for swimming in the pool, among other things. For me too, the number of laps I swam was counted at random. Yesterday I swam with the SR for the first time and the number was tracked just right. may be random, but the algorithm in the race is probably better.
        L Jamie BGJ 2 Replies Last reply Reply Quote 2
        • L Offline
          logger Bronze Member @Rango
          @Rango The Race has been accurate for too when pool swimming, with no issues and correct distance.
            zen_pavel
            @logger @Rango Thank you for replies!
            Can I ask you to share some app screenshots with swims for me to understand what data I’ll be able to get?
            RangoR 1 Reply Last reply Reply Quote 0
            • RangoR Offline
              Rango @zen_pavel
              • renton82R Offline
                renton82 Platinum Member
                It’s a pity that you can’t add swim drill. Drills are important part of my pool swim training, so i can’t use any Suunto watches for swim (apart Ambit 3 and some others old models).
                1 Reply Last reply Reply Quote 5
                • EgikaE Offline
                  Egika Platinum Member @zen_pavel
                  @zen_pavel if you can swim a lane pretty uninterrupted, all will be fine.
                  If you need to stop mid-lane for someone blocking the lane, it might happen, that the watch counts an extra lap.
                  inkognitoI 1 Reply Last reply Reply Quote 2
                  • inkognitoI Offline
                    inkognito Platinum Member @Egika
                    @Egika My S9 taught me to keep moving my left hand (at least slightly, approximately at the same rate as when swimming) whenever I am forced to stop mid-lane. It works great, although I must look a bit loony. 😆
                    SV: fingers crossed :D
                    S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                    Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                    Despite some pretty bad luck, I still love Suunto!
                    1 Reply Last reply Reply Quote 3
                    • Jamie BGJ Offline
                      Jamie BG Bronze Member @Rango
                      @Rango
                      F7/E2 have that stupid auto-rest feature - while it works for some its mostly doesn’t - we tend to move around too much while resting causing it to trigger another lap.
                      But yes if lanes are jammed E2 can count additional lap due to having to stop in lane. Normally just switch to a slower stroke so lane count is good, but does change lap to mixed stroke.
                      zen_pavelZ 1 Reply Last reply Reply Quote 0
                        zen_pavel @Jamie BG
                        @Jamie-BG it was way worse in my case. I didn’t stop, but slowed down and that added laps on F7. But at the same time several laps were missed without any obvious reason (I push every time at the begging).
                        Going to give a try to Race and hope for the best)
                        • leafs93L Offline
                          leafs93 Bronze Member
                          Swam twice with my SR, and like my SV, it is still quite disappointing. In fact it’s worse for my SR. After both my swim, my watch showed 0 distance, and after syncing , my app showed 1,120 meters. Then when uploaded to strava, distance was 1,079. Correct distance should be 1,000. Each lap is 40m. Anyone experienced the same ?
                          Kostas ZinelisK 1 Reply Last reply Reply Quote 0
                          • Kostas ZinelisK Offline
                            Kostas Zinelis Bronze Member @leafs93
                            @leafs93 Did you calibrate the swimming pool length on your watch before starting the activity?
                            leafs93L 1 Reply Last reply Reply Quote 0
                            • leafs93L Offline
                              leafs93 Bronze Member @Kostas Zinelis
                              @Kostas-Zinelis calibrate as in indicate the pool length ? Yes I did.
                              • leafs93L Offline
                                leafs93 Bronze Member @leafs93
                                @leafs93 Watch indicated 0 distance even though the app after sync was 1120 meters. I have calibrated the pool length to 40m per lap. The correct distance I swam should be 1000m or 25 laps. And the weird thing is strava when sync is an even more weird number of 1079. Nothing unusual about my swim motion as I was wearing my Garmin 965 and it had no trouble detecting the right distance of 1000m
                                Joakim ÅgrenJ 1 Reply Last reply Reply Quote 1
                                • Joakim ÅgrenJ Offline
                                  Joakim Ågren @leafs93
                                  @leafs93 said in Swimming pool:
                                  What neon/flourescent yellow strap is that you are using in this photo?
                                  • leafs93L Offline
                                    leafs93 Bronze Member @Joakim Ågren
                                    @Joakim-Ågren just another 22mm strap I bought online… very similar to suunto 9 lime strap.
                                    • leafs93L Offline
                                      No swimmers here facing this issue of watch showing zero distance on lap pool? I was hoping the new firmware would fix this but it is still showing zero distance on my watch but when sync with app, the app would correctly show the distance . Anyone ?
                                      Ars VitaeA A 2 Replies Last reply Reply Quote 0
                                      • Ars VitaeA Offline
                                        Ars Vitae Silver Members @leafs93
                                        Unfortunately, the algorithm for counting pool lengths often fails. The conditions mentioned by other users on this forum to be met are not sufficient and you will either have to wait for an algorithm fix or a new watch. I myself am disappointed by this fact. In my case, the watch, SV, does not count all the lengths swum, at least 30%…
                                        • leafs93L Offline
                                          leafs93 Bronze Member @Ars Vitae
                                          @Ars-Vitae I can understand if some laps are not counted. My issue is different as the laps are counted, just that they are not reflected on watch ( reflected as zero distance ) but on my Suunto App after syncing. Seems there ain’t many others with this issue though.
                                          Ars VitaeA ahmetaktanA 2 Replies Last reply Reply Quote 0
                                            @leafs93 Indeed, that’s what you wrote, my fault for misreading. In that case I envy you, I would like to have at least such a problem, at least an accurate value in the Suunto App.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
