    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Spring - hiking - trekking - altitude
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    22 Posts 12 Posters 2.0k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Piotr GrygielP Offline
      Piotr Grygiel
      Due to the need to set the altitude at the beginning, I suggest adding quick access to settings to the outdoor widget.
      Suunto Race 2
      Google Pixel 8 pro
      isaziI 1 Reply Last reply Reply Quote 2
      • isaziI Offline
        isazi Moderator @Piotr Grygiel
        @Piotr-Grygiel adding config to widgets is planned for what I know. But you do not really need to set altitude before an activity, Fusedalti calibrates altitude within the first 15 minutes, and then applies the correction back to the start.
        Blog: isazi's home
        Piotr GrygielP 1 Reply Last reply Reply Quote 1
          Piotr Grygiel @isazi
          @isazi If you feel like standing still 15 minutes outside in an open area…
          Suunto Race 2
          Google Pixel 8 pro
          L EgikaE sartoricS 3 Replies Last reply Reply Quote 0
          • L Offline
            Likarnik Gold Members @Piotr Grygiel
            @Piotr-Grygiel you can start activity and walk 🙂
            • EgikaE Offline
              Egika Platinum Member @Piotr Grygiel
              @Piotr-Grygiel just use the watch.
              The FusedAlti algorithm will start sampling GPS altitude data and align those with the barometric sensor input.
              Then as isazi said, after like 12-15mins, the GPS altitude information is usually good enough to adjust the altimeter.
              No need to wait for this - it’s working in the background during the activity and does its magic unnoticed 🙂
              t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
              • sartoricS Offline
                sartoric Moderator @Piotr Grygiel
                @Piotr-Grygiel
                you’re missing a detail in isazi reply
                SVTS - 2.48.16
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Samsung A33 2022 - Android 15 - One UI 7.0
                Suunto App Android 6.4.7 beta
                Suunto App IOs 3.6.0 (20927) beta on MBP M1 Max
                Piotr GrygielP 1 Reply Last reply Reply Quote 2
                  Piotr Grygiel @sartoric
                  @sartoric In difficult terrain, forest it works poorly.
                  Suunto Race 2
                  Google Pixel 8 pro
                  sartoricS E Brad_OlwinB 3 Replies Last reply Reply Quote 0
                  • sartoricS Offline
                    @Piotr-Grygiel said in Spring - hiking - trekking - altitude:
                    what ?
                    SVTS - 2.48.16
                    freeheelerF 1 Reply Last reply Reply Quote 0
                    • freeheelerF Offline
                      freeheeler @sartoric
                      @sartoric
                      I also have a different observation and opinion, but I am not there, so I can not contradict 🙂
                      living sideways
                      • E Offline
                        el2thek Bronze Member @Piotr Grygiel
                        @Piotr-Grygiel Do you have an example?
                        Piotr GrygielP 1 Reply Last reply Reply Quote 0
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator @Piotr Grygiel
                          @Piotr-Grygiel I don’t find that to be the case. I never adjust the altitude on my watch. I let FusedAlti do its work.
                          Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                            Piotr Grygiel @el2thek
                            @el2thek The same place 204-238 m 😞
                            Suunto Race 2
                            Google Pixel 8 pro
                            E 1 Reply Last reply Reply Quote 0
                            • E Offline
                              @Piotr-Grygiel how is the gps? Would assume that is also somewhat off then.
                              • SuperFlo75S Offline
                                SuperFlo75 Silver Members Bronze Member
                                Do you use the performance mode? AFAIK fused alti is not working in the endurance mode…
                                Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                                Suunto Wing
                                Suunto 9 Peak Pro Titanium (owns my wife now)
                                Suunto Spartan Ultra
                                SA iOS 3.6.1 (21050)
                                Instagram @superflo75
                                • D Offline
                                  deserthike20 Bronze Member
                                  It’s been mentioned in these before in these forums that manually calibrating the altimeter prior to starting an activity effectively inhibits Fused Alti for that activity. So you may inadvertently be affecting the accuracy by manually entering the starting altitude.
                                  Personally, I never calibrate the altimeter no matter how far off it is and just let it do its magic during the first 15 or so minutes of the activity.
                                  I’ve never read how long before an activity this applies……
                                  Suunto 9 Peak Pro
                                  Suunto Vertical
                                  freeheelerF Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 4
                                    freeheeler @deserthike20
                                    @deserthike20
                                    it used to be 15min before activity afair but seems not to be valid anymore.
                                    I did a test recently with manual adjustment, then immediate activity start and fusedalti did it’s job anyway
                                    living sideways
                                      Dimitrios Kanellopoulos Community Manager @deserthike20
                                      @deserthike20 yes. Calibrating the altimeter before the activity with a -+15m real difference can influence the fused alti not to kick in for the first time.
                                      What is said here is correct.
                                      However keep in mind that fused alti always will kick in either continually and if the difference is more than 15m then also instantly if it has not happened before.
                                      Also keep in mind that the reference altitude must be of the same format. MSL
                                      Creator of Quantified-Self.io
                                      youtube.com/c/dimitrioskanellopoulos
                                      https://instagram.com/dimitrioskanellopoulos
                                      https://www.strava.com/athletes/7586105
                                      D vjakubV 2 Replies Last reply Reply Quote 3
                                      • D Offline
                                        deserthike20 Bronze Member @Dimitrios Kanellopoulos
                                        @Dimitrios-Kanellopoulos @freeheeler
                                        Thank you both for adding and clarifying how Fused Alti works.
                                        Suunto 9 Peak Pro
                                        Suunto Vertical
                                          Piotr Grygiel @deserthike20
                                          An example of Fused Alti precision. Actual height from professional measurement on my wrist 218 m. In my S9PP it was 212 m.
                                          S9PP sets the altitude at this point from 199 to 228 m. My yard is flat.
                                          Screenshot_20230419-075257.jpg Screenshot_20230419-075040.jpg Screenshot_20230419-074945.jpg Screenshot_20230419-074915.jpg
                                          Suunto Race 2
                                          Google Pixel 8 pro
                                            Piotr Grygiel @Piotr Grygiel
                                            Suunto Race 2
                                            Google Pixel 8 pro
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
