    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    [iOS] 1.0.1 (6183) Movescount - Suunto Routes restriction
    Scheduled Pinned Locked Moved Suunto app and other software services
    101 Posts 16 Posters 16.9k Views 14 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • aldnetA Offline
      aldnet
      About this restriction introduced in the last version:
      • Some operations, such as syncing routes created with Suunto app, will prevent a paired Spartan device from syncing activities to Movescount.com in the future. A warning dialog is now shown before performing such operations.
      The warning in the app is not saying nothing about the future, the message seems that if we use this option, activities will stop to sync to Movescount
      Is this true?
      I have a route already synced from Suunto App to the watch, this will activate this scenario?
      If the answer is yes, what should I do to avoid that?
      Can I remove the route and nothing will change?
      My intention, at least some more months, is keep activites sync in both apps.
      Suunto 9 Baro Black (2.11.38)
      Suunto App IOS 1.50.0 (8284)
      iPhone 11 Pro (iOS 14 Beta 4)
      J 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager
        good question.
        Maybe @Jouko-from-Suunto need to shed some light here
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        • SlaShS Offline
          SlaSh Platinum Member
          I have route created and synced via suunto app as well, how to delete it?
          FOUND!
          aldnetA 1 Reply Last reply Reply Quote 0
          • aldnetA Offline
            aldnet @SlaSh
            @slash in the map section, in the bottom left button you could see the list of the routes and remove from the watch, but this activate the warning message I was speaking about.
            I will not do nothing till the doubt is resolved
            • J Offline
              Jouko Tyni @aldnet
              @aldnet Had to verify this a bit and this comes from the dev team now: if you have routes created with earlier versions of the app the watch do not go to unsafe mode. Only until you create new route with this version or edit old one the watch will be put to Movescount unsafe mode.
              You may be also interested to learn this detail: If you do push the watch to MC-unsafe mode that and for any reason regret, you must reset the watch in order to recover.
              aldnetA 1 Reply Last reply Reply Quote 2
              • aldnetA Offline
                aldnet @Jouko Tyni
                @jouko-from-suunto thanks, so I will remove the route, and check what happen with a activity I will perform this afternoon.
                And also if it put me in MC-unsafe I will reset as you suggest
                  To be honest I am surprised about this decision and very interested to see how we can still manage both apps sync
                  • aldnetA Offline
                    aldnet @Dimitrios Kanellopoulos
                    @dimitrios-kanellopoulos without syncing routes 😞
                    • ? Offline
                      A Former User @aldnet
                      @aldnet said in [iOS] 1.0.1 (6183) Movescount - Suunto Routes restriction:
                      i do my routes-handling via movescount only, then it should not be a problem at all.
                      as watch settings can just be synced with movescount (app) or suuntolink (pc & cable) i still use mc for all this stuff.
                      SA just for playing around and testing the app - i just sync my excerises there too.
                      • aldnetA Offline
                        aldnet @Guest
                        @asdf123 yes
                        Till all the routes from Movescount could be visible to Suunto App for me the first resource was Movescount
                        Even with the fact that I cannot convert a activity to a route in Suunto App as we could do with MC.
                        • SlaShS Offline
                          Just did a lunch walk and my activity do not sync with MC, I am getting frustrated…
                          • suzzloS Offline
                            suzzlo Moderator
                            so…
                            If you Create and edit routes in MC and just view en SA, will watch sync in both systems?
                            Suunto: Race, S9Peak, Spartan Sport Wrist
                            Garmin: FR745, Edge 530
                            SA topics:
                            • Guides - https://forum.suunto.com/tags/guides
                            • johan6504J Offline
                              johan6504 Silver Members
                              This is a little confusing…I am not ready to give up MC sine this is the way for synk with Strava. Can I keep testing the app or should I remove it? I do all route planing in MC, never in the app…
                              Runner, Swimmer and Swimrunner
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                Dimitrios Kanellopoulos Community Manager @johan6504
                                @johan6504 From what I understand if you use MC for routes you are fine.
                                SlaShS johan6504J 2 Replies Last reply Reply Quote 0
                                • SlaShS Offline
                                  SlaSh Platinum Member @Dimitrios Kanellopoulos
                                  @dimitrios-kanellopoulos problem is that I have deleted routes which were created by suunto app from watch and suunto app and my sync to MC now is affected even without any routes 😕
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                    johan6504 Silver Members @Dimitrios Kanellopoulos
                                    @dimitrios-kanellopoulos Ok, I’ll stay away from the app routes until we know.
                                      Dimitrios Kanellopoulos Community Manager @SlaSh
                                      @slash said in [iOS] 1.0.1 (6183) Movescount - Suunto Routes restriction:
                                      No idea about that.
                                      To be honest I dont like this change and I am a bit on rage here. Must go for a run
                                      johan6504J aldnetA 2 Replies Last reply Reply Quote 0
                                        @dimitrios-kanellopoulos That might turn out to be a good run, good luck!
                                        • aldnetA Offline
                                          @dimitrios-kanellopoulos @SlaSh that was my scenario too. I understand that the fact to delete, put the watch in Movescount-unsafe for what says @Jouko-from-Suunto
                                          Resetting the phone for second time in less than 24 hours, yesterday for problems with gps and battery consume.
                                          J 1 Reply Last reply Reply Quote 0
                                          • aldnetA Offline
                                            aldnet @suzzlo
                                            @suzzlo yes, in fact routes from MC are not displayed in SA.
                                            If we wan to keep using both systems, don’t use route feature in Suunto App.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
