    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Help with burned calories during run
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    24 Posts 7 Posters 3.6k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Timothy1T Offline
      Timothy1
      Hi,
      I’ve owned Peak Pro since end of November and have been happy about it but it estimates of burned calories is puzzling and I help with it.
      Here’s screenshot from Sports Tracer of my last run:
      As you can probably see from stats, I’m not a goal oriented runner. I run for handling stress, fresh air and balancing my other health choices. I’ve started running in December after 6 month break. I’m sure my max speed in picture isn’t true.
      Back to my problem… I don’t believe I burned 1526 kcal during my run that lasted 1h15min and was 11.37km long. My old Garmin Fenix 5 plus always estimated that same run something between 700-800kcal. I’m not expert about these but it would be nice to have somekind consistency.
      Any ideas what’s wrong and tips to fix it?
      I searched here older similar topics and found one where there was about heart rate zones. Could skewed heart rate zones have effect for burned calories? I’ve entered my weight, height, age and resting hr to Suunto app. Peak Pros gave me hr zones that looked bit off so I searched new ones from online and found potentials from Polar blog.
      Old zones:
      • Max 185 bpm
      • Z5 min 161 bpm
      • Z4 min 152 bpm
      • Z3 min 142 bpm
      • Z2 min 133 bpm
      New borrowed zones:
      • Max 185 bpm
      • Z5 min 168 bpm
      • Z4 min 149 bpm
      • Z3 min 131 bpm
      • Z2 min 112 bpm
      Sports Tracker pictures run was done with new zones. I was lot less in Z5 compared to old zones but it didn’t have effect on burnt calories.
      Sorry about this long winded wall of text. If someone has explanation new zones for 35 year old hobbyist runner/jogger I’ll gladly have them.
      TLDR: Burned calories during run looks skewed upwards to me but I’m not expert. I tried to solve this through changing heart rate zones but it didn’t have effect. Hints and tips needed.
      Thanks beforehand!
      zhang965Z sartoricS Brad_OlwinB 4 Replies Last reply Reply Quote 0
      • zhang965Z Offline
        zhang965 @Timothy1
        @Timo-Kauppinen
        My calories from a 10k
        I use the heart rate zones from lab test,
        Winners Wear Winners
        Timothy1T 2 Replies Last reply Reply Quote 0
        • zhang965Z Offline
          zhang965
          I seems Garmin will update your hr zones automatically?
          Suunto 's default hr zones are not realistic
          • sartoricS Offline
            sartoric Moderator @Timothy1
            @Timo-Kauppinen said in Help with burned calories during run:
            Just to be sure, what do you see in watch log and Suunto app ?
            Because data can be messed up since Sport Tracker is not the “official” Suunto app.
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.7.12 beta
            Timothy1T 1 Reply Last reply Reply Quote 1
            • sartoricS Offline
              Did you change it after the run or do you mean you’ve done it before another run ?
              There’s a post somewhere here (search for it) explaining the different ways you can calculate your zones
              SVTS - 2.50.28
              Timothy1T 1 Reply Last reply Reply Quote 0
              • Timothy1T Offline
                Timothy1 @sartoric
                @sartoric That picture is after changing HR zones. Yeah, I’ll try to find info about it… I’d fine just some default ones that would make sense. Maybe I’m someone who thinks he runs casually but body experiences it professional athlete level.
                • Timothy1T Offline
                  Timothy1 @sartoric
                  @sartoric Here’s what my Suunto app shows about that run. I wasn’t aware before until last week that Suunto app is connected with Sports Tracker. I red about it and noticed that I can log in with Suunto account,
                  • Timothy1T Offline
                    Timothy1 @zhang965
                    @zhang965 Yeah, I didn’t even need to change HR zone levels with Garmin because numbers felt reasonable unlike these Suunto ones.
                    • Timothy1T Offline
                      Timothy1 @zhang965
                      @zhang965 Okay, my numbers definitely are wrong then. Could using HR-belt help? Meaning is it presumed that everyone uses HR-belt because OHR is unreliable.
                      E zhang965Z 2 Replies Last reply Reply Quote 0
                      • E Offline
                        el2thek Bronze Member @Timothy1
                        @Timo-Kauppinen Did you check your weight settings?
                        • Timothy1T Offline
                          Timothy1 @el2thek
                          @el2thek I did… Weight is 95 and height 185 as they should be.
                          E 1 Reply Last reply Reply Quote 0
                          • zhang965Z Offline
                            zhang965 @Timothy1
                            I only use hr belt
                            • E Offline
                              @Timo-Kauppinen In that case, based on heart rate and weight the kcal seem plausible. Only thing that would explain the difference is accuracy of heart rate data. Perhaps there’s someone you can borrow a hrm from to check.
                              Zones have no influence on kcal.
                              • Timothy1T Offline
                                Timothy1 @el2thek
                                @el2thek They don’t? Well then I don’t know what to do because I thought maybe they would. Does Peak Pro add BMR burn during run to end calories sum or is it purely burn that running causes?
                                I was considering hrm already but no I have to.
                                Thanks for your help!
                                isaziI E 2 Replies Last reply Reply Quote 0
                                • isaziI Offline
                                  isazi Moderator @Timothy1
                                  @Timo-Kauppinen yes BMR calories are added to the active calories burned for Suunto watches.
                                  Blog: isazi's home
                                  • E Offline
                                    @Timo-Kauppinen Well they do as in lower intensity = lower heart rate (zone) = less energy required, and vice versa. And they do since energy expenditure varies from person to person, similar to the zones. That’s why some formulas take VO2max into consideration.
                                    So in that light changing the zones may somewhat influence the kcal calculation. However, it should only fine tune it, not doubling/halving the kcal.
                                    I probably should have worded is as, they don’t have a big influence (perhaps only if they are way off).
                                    • B Offline
                                      Bradleyd Bronze Member
                                      Looking at the training summary, these specific numbers are prominent outliers that could be driving up the observed total KCal or are correlated with out-of-range or anomalous data:
                                      42 hour recovery is massive for a 75 minute activity
                                      134 TSS feels high for the training time
                                      4.8 PTE is super high for a training with nominal ~6 min/km pace
                                      15.1 km/hr average speed, with max 30.7 km/hr feels like the culprit
                                      Are there any spikes in the running speed time series that are short duration and wouldn’t add up to significant distance, but could be counted as “burst efforts at warp speed”?
                                      • Brad_OlwinB Offline
                                        Brad_Olwin Moderator @Timothy1
                                        @Timo-Kauppinen @zhang965 is very fast and quite fit. His max HR is 185 as well I think. Your zones are set way too low for a max of 185. My max is 181 and my Z3 min is 150. Unless you have very low fitness, which does not appear to be the case the zones are way off. Running an hour in Z4 should be very, very difficult. I could not run an hour in Z4, maybe 30 min or less.
                                        Sports tracker does not set up my zones appropriately, they are way too low.
                                        Vector/T6c/Vertical 2 Ti
                                        • Timothy1T Offline
                                          Timothy1 @Brad_Olwin
                                          @Brad_Olwin
                                          • Timothy1T Offline
                                            Hi Brad!
                                            Sorry about my first message that got loose.
                                            I ran today same run than before with new HR zones seen in this picture. Most of the time I was in Z3 and barely scratched Z4 for less than minute when running long upwards hill. Maybe these zones are better for me.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
