    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS offset by many meters
    Scheduled Pinned Locked Moved Suunto 9 Peak
    26 Posts 11 Posters 4.5k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • thanasisT Do not disturb
      thanasis Bronze Member
      after tennis training, i had some running and the GPS route had a significant offset for the majority for the route on the 1st leg and a much larger one on the return one. (some 50-100m) maybe .
      i have never seen anything like this before. Can it be a defect?
      DMytroD Łukasz SzmigielŁ isaziI 3 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @thanasis
        @thanasis it could be a bad GPS day ¯⁠\⁠_⁠(⁠ツ⁠)⁠_⁠/⁠¯
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @thanasis
          @thanasis it sometimes happens with S-series watches, and I suspect it’s related to FusedSpeed. Because speed is calculated from watch movement and GPS alike, it may result in offset track when running at constant speed and changing directions. Sometimes, the position is calculated with larger offset and the watch won’t adjust it as it would skew the pace / distance travelled. If you were to stop for a few seconds and then run again, it should adjust.
          It’s simply a matter of prioritizing pace and distance over track accuracy.
          S9PP 2.50.28
          thanasisT 1 Reply Last reply Reply Quote 0
            thanasis Bronze Member @Łukasz Szmigiel
            @Łukasz-Szmigiel said in GPS offset by many meters:
            yes but 50-100m offset is not reasonable
            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
              @thanasis was it 50 - 100m?
              S9PP 2.50.28
                yes the returning leg is about 90m at some points
                freeheelerF 1 Reply Last reply Reply Quote 0
                • freeheelerF Offline
                  freeheeler @thanasis
                  @thanasis
                  I have seen tracks like that when starting the activity too soon and the watch did not sufficiently lock satellites… just as one possible explanation.
                  try a second time, the track is hopefully fine then
                  living sideways
                  Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 2
                  • isaziI Offline
                    isazi Moderator @thanasis
                    @thanasis such big offsets are not very common, never had one with the S9P. Which satellites are you using? Could be wrong hephemeris (especially if you are using Galileo or Glonass).
                    Blog: isazi's home
                    thanasisT 1 Reply Last reply Reply Quote 1
                      thanasis Bronze Member @isazi
                      @isazi said in GPS offset by many meters:
                      GNSS +QZSS+ Galileo actually
                      I haven’t changed this setting since purchase
                      Dimitrios KanellopoulosD isaziI 2 Replies Last reply Reply Quote 0
                        Łukasz Szmigiel @freeheeler
                        @freeheeler correct. Also, being stationary while waiting for GPS lock is helpful.
                        S9PP 2.50.28
                          Dimitrios Kanellopoulos Community Manager @thanasis
                          @thanasis I had those with galilleo. For S9P in GR I only use GPS + BEIDOU
                          Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                            thanasis Bronze Member @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos said in GPS offset by many meters:
                            ok Thanks!! will change accordingly
                            • isaziI Offline
                              @thanasis Galileo is very precise, but sometimes the earth stations are not enough to provide precise hephemeris and monitor the satellites, and when you don’t know the position of the satellites very precisely, you may end up with these kind of errors (among others).
                              Blog: isazi's home
                              1 Reply Last reply Reply Quote 3
                                To be honest and adding to Isaz’s answer, I was very enthusiastic about Galilleo. The thing is that 1/20 or less it has those offsets.
                                For me it looks like a race of giving no position at all vs giving some offset position.
                                That said I am very enthusiastic about dual freq GPS as well 😉
                                thanasisT zhang965Z 2 Replies Last reply Reply Quote 3
                                  what do you mean? s9pp I assume and not s9p
                                  DMytroD 1 Reply Last reply Reply Quote 0
                                  • DMytroD Offline
                                    DMytro @thanasis
                                    @thanasis s9pp does not have dual frequency either (it is a hw limitation/decision, so it’s not like dual frequency can be enabled with software).
                                    • zhang965Z Offline
                                      zhang965 @Dimitrios Kanellopoulos
                                      No I don’t trust you, dual frequency gps is not getting better, you are lying 😠 😠 😠 😭😭😭😭
                                      Winners Wear Winners
                                        Łukasz Szmigiel
                                        Moar precision! Moar satellites! And cell towers for calculating the coordinates! And starlink! And dead reckoning! And the head wobble offset.
                                        And then we’ll discuss how the position should be calculated as it shows the watch position and not its user. Which is, apparently, terrifyingly useless for sports. Such poor precision, that is.
                                        Truth is most of us would be cool with current precision and around 10 - 15s fix.
                                        Technology is awesome, it’s inspiring to see how much data can we extract from such small devices, but then where’s the fun in sports if we’re getting overwhelmed by the data and its precision?
                                        S9PP 2.50.28
                                        • zhang965Z Offline
                                          zhang965
                                          It’s what you can get with GPS on in Amsterdam in-house service lol
                                          • Brad_OlwinB Offline
                                            Brad_Olwin Moderator @zhang965
                                            @zhang965 said in GPS offset by many meters:
                                            I think for where you run dual frequency may matter. There are typically few trees and no tall buildings where I run so I do not see differences but……you sparked my memory. I think I was still testing the S9P. But, here is a comparison of the Epix2 running dual band with the 9Peak in Utah slot canyons. Here the dual band made a huge difference.
                                            https://quantified-self.io/user/dwRCM1JtltMCKS5E4SYCPN0s4lj1/event/0Zpqxa7IkKPK62YHSUyP
                                            Vector/T6c/Vertical 2 Ti
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
