    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude data when running in heavy rain
    Scheduled Pinned Locked Moved Suunto 9 Peak
    27 Posts 14 Posters 5.3k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      aligigi Bronze Member
      I ran on a route that I usually run in a pretty heavy rain and the altitude graph came out all jagged with little spikes and I also got more total ascent and descent than usual. Below are the pictures with the alti graph and data from the rainy run and one from a run on the same route in good weather.
      It was not very windy, just a heavy pouring rain.
      On both occasions I wore a t-shirt with short sleeves so I had no clothes covering the watch.
      It’s the small spikes in altitude reading that add up to wrong data, looking at the graph on any given point the altitude value seems correct.
      I have one other run also in heavy rain with jagged alti graph and ascent/descent values that are too high and I have runs in good weather for comparison for that route too.
      I’m not complaining, I figured that maybe somebody could find this useful.
      Rain:
      And in clear weather:
      freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 3
      • freeheelerF Offline
        freeheeler @aligigi
        @aligigi
        looks like the hole position is prone to weather conditions like drops maybe hitting directly the baro holes and hence increase the inside pressure? in heavy rain it is likely to hit even small spots like these… or, depending how fast you run the impact of wind, caused by speed and arm movement could also increase pressure temporary … OR gusts… maybe we learn about this a bit more over time?
        living sideways
        • ? Offline
          A Former User
          I’d assume the same as freeheeler. The pressure sensor is extremely sensitive to water. Since water is much denser and heavier than air, that’s quite normal. And since the sensor is rather exposed on the S9P, a drop that hits the sensor holes can probably cause a spike in the altitude measurement. GPS and FusedAlti then probably correct the absolute altitude, resulting in a zig-zag in the diagram and an increase in total ascent/descent. Just a theory, but anyways, rather expected behavior and not a defect.
          freeheelerF 1 Reply Last reply Reply Quote 1
            freeheeler @Guest
            @simon
            FusedAlti does not react that fast.
            I know from my S9B that the built up pressure is relieved relatively fast, hence it’s a short down spike and comes back to normal quickly again.
            but I see the hole position on S9P has more advantages than S9B 👍
            living sideways
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @aligigi
              @aligigi I have had this happen ski touring when a lot of snow covers my hands/arms and water gets into the baro holes.
              Vector/T6c/Vertical 2 Ti
              • Panagiotis KritikakosP Online
                Panagiotis Kritikakos Gold Members
                For the sake of information, I had the same “issue” today (again). Two hours riding in the rain, occasionaly heavy and windy. The elevation recorded was more than x2. I was wearing both jacket and gloves while the watch was exposed and not covered. Never had this issue when the watch is attached on the bike mount. I attach the relative screenshots along with Strava data after elevation correction.
                Suunto Vertical Titanium Solar | 9 Peak | Ambit 3 Peak | 3 | Gekko
                Garmin eTrex 30x
                  freeheeler @Panagiotis Kritikakos
                  @Panagiotis-Kritikakos
                  the hole position is better than on the side of the watch, where you could block them with your skin or jacket sleeve with basically every motion. the holes pointing upwards where raindrops can hit the holes directly is a better compromise IMO.
                  if you don’t need to look at the watch frequently I would cover it with the rain jacket and the problem should be minimized
                  edit: thanks @cosme-costa , didn’t notice that I already replied something similar some time ago 🙈
                  living sideways
                  A 1 Reply Last reply Reply Quote 1
                  • A Offline
                    aligigi Bronze Member @freeheeler
                    @freeheeler I did have a chance to test that theory, a few weeks ago some really heavy rain cought me at home with nothing to do so I went out for a run. I wore the watch upside down on my wrist with the holes looking down and the buttons oriented towards my elbow. I ran the same course and the elevation was correct. I guess that with the holes looking down the raindrops could not affect the baro sensor.
                    1 Reply Last reply Reply Quote 4
                    • jjpazJ Offline
                      jjpaz Bronze Member
                      I had same issue last week. With heavy rain water drops block baro sensor holes in S9P.
                      When running and hands pointing forward, the holes are pointing up. Baro holes are more exposed than S9B in that conditions.
                      After that, when it’s raining I try to turn hand a bit to “protect” holes and clean water drops in the holes every 5-10min.
                      With light rain no problem.
                      Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                        @freeheeler Another rainy ride today, at least for the most part, not as heavy and wind as yesterday, but I covered the watch under the jacket. Elevation profile and ascent/descent values were right and the profile smooth.
                        Anyway, IMHO that behaviour with the positioning of baro holes for an outdoor watch with barometric altimeter (it’s one of the features that make me choose GPS products and I guess it’s not only me) could be a bit of problematic design. I don’t know the limitations and what leads at the positioning of the sensor/holes but from a customer perspective I’d like my barometric device to behave as expected on bad weather and when it’s normally positioned on the hand, instead of covering, turning upside/down etc.
                        Garmin eTrex 30x
                        DMytroD 1 Reply Last reply Reply Quote 3
                        • DMytroD Offline
                          DMytro @Panagiotis Kritikakos
                          @Panagiotis-Kritikakos with previous models holes were positioned on the side. This however caused bad values to occur because of wind gusts and also due to contact with sleeves if I recall correctly. I guess, no matter the position, there’ll always be some give and take. Unless suunto places multiple sensors on each side to make a cross reference. That might be am overkill tho, instead I’d prefer to have a post workout correction in SA, akin to Strava.
                          Panagiotis KritikakosP 1 Reply Last reply Reply Quote 1
                            Panagiotis Kritikakos Gold Members @DMytro
                            @DMytro I’m sure, it can be tricky. Don’t know how other watches from other manufactures behave. Post workout correction is ok. It’s done on Strava but still missing in SA. My main concern is during the activity, especially for mountain oriented activities where the watch is on hand.
                            Garmin eTrex 30x
                            • inkognitoI Offline
                              inkognito Platinum Member
                              So, nice solution would be to introduce the option to choose from “FusedAlti” and “GPS only” somewhere in the navigation/elevation settings, right? And make these options accessible during the exercise…
                              My main concern why I chose Suunto 9 non-baro instead of Suunto 9 baro was that I’d rather have expectedly less precise elevation metrics than totally wrong values in some cases (rain, after swimming, heavy sweating, strong wind, possible sensor failure, etc)…
                              SV: fingers crossed :D
                              S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                              Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                              Despite some pretty bad luck, I still love Suunto!
                              Panagiotis KritikakosP sartoricS 2 Replies Last reply Reply Quote 1
                                Panagiotis Kritikakos Gold Members @inkognito
                                @inkognito That could be an option to prevent misleading readings from the start.
                                Garmin eTrex 30x
                                • sartoricS Offline
                                  sartoric Moderator @inkognito
                                  @inkognito
                                  Maybe and maybe not
                                  Consider that if it’s heavy raining, probably the gps signal is sh***y too ?
                                  SVTS - 2.50.28
                                  SSSWHR BARO Amber - 2.8.32
                                  Samsung A5 2016 - Android 7.0
                                  Suunto App Android 6.11.12 beta
                                    Again today, with very strong wind, the baro sensor seem to have failed tragically. For an ascent of about 1300m, the watch reported 5500m! I was standing still, the baro graph along with meters of ascent were going mad. For an outdoor watch, failing to operate properly in not ideal/friendly conditions is bad, espeically when such fetaures are reasons for buying the device at first place.
                                    ![alt text](Screenshot_20230226-161427.png Screenshot_20230226-161529.png image url)
                                    Garmin eTrex 30x
                                    DMytroD Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                    • DMytroD Offline
                                      @Panagiotis-Kritikakos but do you know if competition has better results in such conditions?
                                      I think it would be helpful for users to be able to switch to gps-altitude if the recognize that conditions interfere with baro measurements.
                                      Panagiotis KritikakosP 1 Reply Last reply Reply Quote 0
                                        @DMytro Generally, no I don’t know. If they have similar it doesn’t justify the result. My mate however with Garmin didn’t have such issues today.
                                        GPS/baro switch has been mentioned before and I think would be helpful.
                                        Garmin eTrex 30x
                                        thanasisT ? Jeffrey TillackJ 3 Replies Last reply Reply Quote 2
                                          Brad_Olwin Moderator @Panagiotis Kritikakos
                                          @Panagiotis-Kritikakos I have had this happen as well. About the only solution is to wear under your shirt sleeve or jacket.
                                            Panagiotis Kritikakos Gold Members @Brad_Olwin
                                            @Brad_Olwin It was under the jacket, but the sleeve was not very tight to the wrist and I had headwind.
                                            Garmin eTrex 30x
                                            freeheelerF 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
