    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 peaks bug
    Scheduled Pinned Locked Moved Suunto 9 Peak
    32 Posts 11 Posters 4.1k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • emanuele truccoloE Offline
      emanuele truccolo
      Hello, I found a bug on the lap screen (during activity), if I change the first field on the left (where usually there is the lap distance) Suunto 9 peaks shows always the lap distance also if I change it. Is it normal ?
      isaziI 2 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator @emanuele truccolo
        @emanuele-truccolo not normal, I’ll report it to Suunto after testing.
        Blog: isazi's home
        • aroo7A Offline
          aroo7 Bronze Member
          after the last update, S9P has problems with registering a valid GPS track:
          yesterday:
          and today:
          the green dotted line is the real trace of my run
          I have never observed similar problems before on S9P
          it looks like the watch freezes for a few minutes and doesn’t register a GPS signal
          omunozO isaziI 2 Replies Last reply Reply Quote 0
          • omunozO Offline
            omunoz Silver Members @aroo7
            @aroo7
            The same with me first workout as s9p update : https://www.suunto.com/move/omunoz/6156f608134a046087b852b3
            Seems that needs more time to chose the gps signal in the first workout after upgrade .
            Watch: SV Fw: 2.40.44
            IPhone 13 (Sim) IOS 18.5
            Android 15.0 with Android Studio
            macOS Sequoia 15.5 M1 & M2
            Apps IOS: 2.45.3 (19258)
            Apps Android: 4.107.2 (40107002)
            • isaziI Offline
              isazi Moderator @aroo7
              @aroo7 Galileo?
              Blog: isazi's home
              aroo7A 1 Reply Last reply Reply Quote 0
              • aroo7A Offline
                aroo7 Bronze Member @isazi
                @isazi that’s right
                isaziI TonyGT 2 Replies Last reply Reply Quote 1
                • isaziI Offline
                  @aroo7 thanks, I have been seeing some issues with Galileo (Suunto should be aware of that).
                  Blog: isazi's home
                  aroo7A 1 Reply Last reply Reply Quote 2
                  • TonyGT Offline
                    TonyG Silver Members @aroo7
                    @aroo7 I am getting good tracks from using GPS only.
                    • G Offline
                      guy.s
                      I’ve had a dropout which I put down to Galileo. But the rest of the time the accuracy has been stunning.
                      isaziI 1 Reply Last reply Reply Quote 1
                      • isaziI Offline
                        isazi Moderator @guy.s
                        @guy-s said in Suunto 9 peaks bug:
                        Same here, usually the accuracy with Galileo is perfect, but sometimes that are unexplained drops that the other systems do not have. Therefore I am back to using Beidou.
                        Blog: isazi's home
                        C 1 Reply Last reply Reply Quote 0
                        • aroo7A Offline
                          aroo7 Bronze Member
                          Thanks guys for letting me know 👍
                          • C Offline
                            chrisc92 Bronze Member @isazi
                            @isazi i also noticed my first GPS drop with S9P and Galileo after the update 53FEBEB9-8EC1-4633-B0E6-46512DB001AA.jpeg
                            Do you recommend Beidu also for Western Europe (France) ?
                            isaziI Rick StockwellR 2 Replies Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @chrisc92
                              @chrisc92 there are issues with Galileo at the moment, I suggest to try Beidou and see how it works (I’m in the Netherlands).
                              Blog: isazi's home
                              • Rick StockwellR Offline
                                Rick Stockwell @chrisc92
                                @chrisc92 I’m having great results with Glosnass in Colorado (US)
                                • isaziI Offline
                                  @emanuele-truccolo do you have auto-laps enabled, right? When enabled the first field is always the auto-lap metric, this I am being told by Suunto.
                                  Blog: isazi's home
                                  emanuele truccoloE 1 Reply Last reply Reply Quote 0
                                  • R Offline
                                    Ramrod
                                    Can you manually select which GPS service the watch uses?
                                    DMytroD 1 Reply Last reply Reply Quote 0
                                    • DMytroD Offline
                                      DMytro @Ramrod
                                      @ramrod yes, in the navigation settings, outside of an activity.
                                      R 1 Reply Last reply Reply Quote 1
                                        emanuele truccolo @isazi
                                        @isazi No autolap
                                        • isaziI Offline
                                          @emanuele-truccolo I will test and get back to you soon.
                                          Blog: isazi's home
                                          • isaziI Offline
                                            @emanuele-truccolo for me it works if I disable auto lap. Which field are you using for the first column?
                                            Blog: isazi's home
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
