    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Subterranean outdoor activities with Galileo
    Scheduled Pinned Locked Moved Suunto 5
    22 Posts 5 Posters 4.4k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel
      There used to be a bug - a long time ago (fixed in some of the firmware updates) - that made a sudden drop (or rise, I can’t remember) in altitude on the start of the activity when using Galileo. I’ve been observing similar behavior for some time and was wondering if it’s firmware related or maybe there were some internal changes to GNSS itself?
      For example, I’ve started today’s run, according to SA at -36m and quickly (around 60s) went to nominal ~120m. What’s interesting - the track was acceptable - pretty typical for first few minutes, with some deviations but nothing bad like being 100m off the actual location.
      Apart from the start, the track was top notch, no signal losses or weird deviations.
      So I got an ascent of 162m when it should be around 10m.
      S9PP 2.50.28
      DMytroD 1 Reply Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @Łukasz Szmigiel
        @łukasz-szmigiel oh, I didn’t know it might be Galileo related. I get it almost every time of I start workout directly after arrow turns green, if you give it few more seconds it should be fine though.
        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
          Łukasz Szmigiel @DMytro
          @dmytro I usually wait a little longer or start running without actually starting the workout and it’s mostly OK but it goes bonkers from time to time (like today). I thought that this problem was sorted out but maybe not?
          S9PP 2.50.28
          • DMytroD Offline
            @łukasz-szmigiel I didn’t thought of it as a problem tbh. It’s just that GPS needs time to settle and the arrow turns green not when the signal is great but when it’s good enough.
              @dmytro yeah it might be a matter of how it’s tuned in to show that the signal is good enough (and it doesn’t care about VDOP) but I haven’t seen it with other GNSS which is strange. Or maybe I’m not using other GNSS often enough to notice?
              S9PP 2.50.28
              Tomas5T DMytroD 2 Replies Last reply Reply Quote 0
              • Tomas5T Offline
                Tomas5 Gold Members @Łukasz Szmigiel
                @łukasz-szmigiel i don’t have problem with altitude at all or at least i didn’t notice. For example from last bike. But i every time wait for GPS signal befor starting excercise. And it took usually longer. Around 20-30 seconds sometimes less or more. Maybe you just need to wait few seconds more before starting excercise.
                And latest hike:
                Suunto Ambit 2 > Suunto 5 > Suunto Race 2
                • DMytroD Offline
                  @łukasz-szmigiel I use Galileo and it’s there every time I rush the wait. I’ll try other combinations out of interest.
                  Tomas5T 1 Reply Last reply Reply Quote 0
                  • Tomas5T Offline
                    Tomas5 Gold Members @DMytro
                    @dmytro i use galileo too.
                      Łukasz Szmigiel
                      Just a friendly reminder that a gigantic drop of altitude at the beginning of the activity is still there, mostly when using two GNSS, oftentimes Galileo. This is very frustrating, especially now when we have a brand new ascent / descent algorithm. Any chances it’s going to get fixed?
                      S9PP 2.50.28
                      Tomas5T 1 Reply Last reply Reply Quote 1
                      • Tomas5T Offline
                        @łukasz-szmigiel did’t tried it yet with new firmware but since you mentioned it last time. I was looking at this and i have this issue too. Not every time but usualy it is few tenths or even hundreds meters. But there are some exceptions without any altitude drop. I use gps + galileo all the time. If weather stay good i will report tomorrow test with latest firmware. And in my case it starts on higher altitude and then drops down to real altitude. I just noticed you have it in oposite direction.
                          Łukasz Szmigiel @Tomas5
                          @tomas5 it typically drops from too high, approx 70 - 90 meters during first 30 - 60s of workout
                          S9PP 2.50.28
                          • Tomas5T Offline
                            @łukasz-szmigiel i been on bike today, no issue with altitude drop at begining. But before i pressed start i was waiting for another minute after green gps icon apeared because i was setting up navigation and suunto plus feature.
                              @tomas5 this is well known. Although I’d like to know whether I should wait for ten more seconds or two more minutes.
                              S9PP 2.50.28
                              freeheelerF 1 Reply Last reply Reply Quote 1
                              • freeheelerF Offline
                                freeheeler @Łukasz Szmigiel
                                @łukasz-szmigiel
                                it is the first time I see it that obvious since the campground is really flat.
                                in this case, yes it would be helpful to distinguish between satellite lock and “altitude lock” 🙂
                                living sideways
                                isaziI 1 Reply Last reply Reply Quote 0
                                • isaziI Offline
                                  isazi Moderator @freeheeler
                                  @freeheeler for activities shorter than 15 minutes the issue is that fusedalti may not kick in.
                                  Blog: isazi's home
                                    freeheeler @isazi
                                    @isazi
                                    I know, it was around 30mins
                                    living sideways
                                    • Tomas5T Offline
                                      Tomas5 Gold Members @freeheeler
                                      Today on bike i didn’t have problem with altitude at beginning. But it is funny that lowest point is 375m, highest point is 979m. But my ascent is only 557m which is less than difference between lowest and highest point. By suunto app map planer it should be around 800m. But without barometer i don’t have big expectations from this measurement.
                                      Łukasz SzmigielŁ isaziI 2 Replies Last reply Reply Quote 0
                                        @tomas5 I don’t expect it to be perfect. I just want to know when to start the activity 😄 my experience when trekking is that I usually get 1 - 3m error in altitude when checking on marked peaks, with S5 and Galileo. And I find it remarkable.
                                        S9PP 2.50.28
                                        • isaziI Offline
                                          isazi Moderator @Tomas5
                                          @tomas5 yes depending on the route itself you may see less ascent with baroless devices because of the 7m threshold.
                                          Blog: isazi's home
                                          Tomas5T 1 Reply Last reply Reply Quote 2
                                          • Tomas5T Offline
                                            Tomas5 Gold Members @isazi
                                            @isazi yes probably this reason, when i checked altitude against marked peaks I have same result as @Łukasz-Szmigiel usually few meters difference, only rarely few tens of meters.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
