    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Swimming GPS accuracy of Suunto 5
    Scheduled Pinned Locked Moved Suunto 5
    29 Posts 12 Posters 7.5k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tomas5T Offline
      Tomas5 Gold Members
      Hello i know that receive of gps signal of watch in water is very limited. I did few open water swims in lake last days. I waited for GPS to have fix before swiming. I swim brest style, so watch is close to surface all time. With Ambit 2S it recorded my position every few 10 of meters. Without any issue. It was enough that watch, from time to time was elevated about surface for just 2-3 seconds. With Suunto 5 i must stop swimming and raise hand few cm from water. Than i need wait for 10-30s, for watch to record distance. So on lake i need to stop every 100m and wait almost half a minute (for watch to catch GPS) so i can turn my direction. Is this normal for suunto 5? Because i don’t know if i have defective unit or suunto 5 performance in wather is just much worst than it was with ambit 2. Next time i will try to take my old watch for swim to compare directly on same hand. But i doub that my swimming style changed since last year.
      Suunto Ambit 2 > Suunto 5 > Suunto Race 2
      sartoricS Dimitrios KanellopoulosD Kai SlyK angela angelaA 4 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Tomas5
        @tomas5 said in Swimming GPS accuracy of Suunto 5:
        If you think you could have a defective unit, I guess it would be better (and faster) to contact support.
        Regarding GPS precision in open water swimming you can find loads of discussion.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
          Dimitrios Kanellopoulos Community Manager @Tomas5
          @tomas5 it’s not the first time I see this. Actually I had the same with my s9P.
          I’ll keep you posted. Let the next week start to get some feedback.
          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          Tomas5T 1 Reply Last reply Reply Quote 1
          • Tomas5T Offline
            Tomas5 Gold Members @Dimitrios Kanellopoulos
            @dimitrios-kanellopoulos i will compare next week with old ambit if weather will be still good. I don’t swim open water a lot. But it was strange that i had to wait on other side of lake to gps to catch signal. Never noticed this with ambit 2s.
            sartoricS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
            • sartoricS Offline
              @tomas5 The antenna makes a big differnce
              SVTS - 2.50.28
              Tomas5T 1 Reply Last reply Reply Quote 0
              • Tomas5T Offline
                Tomas5 Gold Members @sartoric
                @sartoric it is possible, thats reason i posted here and not contacted suunto directly because it is possible that it is normal for S5. I wanted to know experience of other s5 users. I wasn’t satisfied with accuracy when hiking too. But thanks to other users i found out that on average, combination gps+glonass is best for hiking and accuracy is quite well.
                  @tomas5 different chip friend.
                  I have exactly the same issue. Once the hand stays a lot in the water it drops the gps and take a lot of time to find it. 10s or so.
                  So it requires effort to keep the pace and track ok.
                  Suunto is investigating it with Sony. Was not like this before. Possibly it’s a regression of a recent fw update on the gps chip. I have tracks from 2018 that are perfect.
                  Tomas5T 2 Replies Last reply Reply Quote 3
                  • Tomas5T Offline
                    @dimitrios-kanellopoulos thanks for info. If it will be fixed it would be great. I don’t swim much but i like to track it if possible.
                    • Tomas5T Offline
                      @dimitrios-kanellopoulos next summer is here in few months, do you know if there is some progress in solving this issue?
                      Djordje SD 1 Reply Last reply Reply Quote 0
                      • Djordje SD Offline
                        Djordje S Bronze Member @Tomas5
                        @tomas5 I have the same issue with S9.Had to wait 10-30 sec to update parameters.Hope it will be fixed before summer 🙂
                        • Kai SlyK Offline
                          Kai Sly @Tomas5
                          @tomas5
                          Breaststroke is probably not the best choice for OWS Swimming distance measurement accuracy. All watches (Polar, Garmin, Suunto etc.) have an issue because of the GPS Signals and the arms not surfacing. If you want accurate distance readings, you should always put the watch in the Tow float or under your Swim cap.
                          Tomas5T 1 Reply Last reply Reply Quote 2
                          • Tomas5T Offline
                            Tomas5 Gold Members @Kai Sly
                            @kai-sly i had ambit 2 for many years and it worked well, that is why my expectation are that this should work.
                            • angela angelaA Offline
                              angela angela @Tomas5
                              @tomas5 None gps watch works on breast stroke unless you put the watch under your swimming cap.
                              S9P moss grey
                              S5
                              • Tomas5T Offline
                                Tomas5 Gold Members @angela angela
                                @angela-angela i had ambit 2 on my wrist and it worked much better than S5. It doesn’t record while swimming, but when i was on end of lake and i wanted to go back i just put my hand for 2-5 seconds and it got gps signal to record my position. With S5 it take around 20 seconds which is much more harder to do when swimming in lake where depth is too deep.
                                V 1 Reply Last reply Reply Quote 0
                                • V Offline
                                  vinay Bronze Member @Tomas5
                                  @tomas5 For those interested, I just checked an activity from yesterday where I did about 1km of openwater swimming halfway my trailrun, using the Suunto 5. I do have Ambit 2 and Ambit 3 watches too, but I never used those to track swimming as I don’t have the appropriate chest strap. Using a Wahoo as it communicates both in ANT+ and Bluetooth. Plus I like how you can switch activities in the Suunto 5. Indeed the swimming track looks jagged as if it only picks up a point every couple of seconds whereas the running track is smooth. It doesn’t bother me too much. Also because I’m not fast or efficient with swimming so the logged track is smooth enough for me ;).
                                  In the attached picture, you see both part of the run and of the swim. And yes, I’m bad at swimming a straight line too ;).
                                  • Tomas5T Offline
                                    Tomas5 Gold Members @vinay
                                    @vinay thanks for info, i think your track looks pretty good compared to main. I usually get fix only when i purposely stop and take my hand out for multiple seconds. I am swimming breast stroke only. So while swimming watch are close to water surface but rarely above surface. But i will do more of openwater swimming next next few weeks so I will see how it will work. ae5dbd00-54f8-4fa8-8963-3476bad39a0a-image.png
                                    • V Offline
                                      @tomas5 Well yeah, could still be that swimming motion is different from mine. I definitely don’t qualify as a skilled swimmer and even though I’d love to call mine a breast stroke too, it may not look like that ;). But chances are I am actually dragging my arm deeper through the water so that may not be the cause. Would the kind of water matter? I was swimming on a small lake, so no salt water. Just trying to find out what the differences are. To be sure, I’m using the regular 5 which, just like the Ambit watches has the external GPS antenna. So not like the more recent 5 Peak which has the antenna under the screen.
                                      • EgikaE Offline
                                        Egika Platinum Member @vinay
                                        @vinay even a very thin layer of a few cm of water will fully block the GPS satellite frequencies. Remember: Civil GPS is using 1600MHz frequencies. These are microwaves, similar to those used ina microwave oven (2400MHz), where their only purpose is to be absorbed by water.
                                        Plus the signal propagatino delay will be differenz under water. Since the whole GPS navigation is based on signal propagation times of a few nano seconds, this will also have an effect.
                                        Conclusion (as said before): Forget about getting anything out of a GPS receiver if the antenna is not frequently lifted out of the water.
                                        If you swim breast stroke, put the watch under your swimming cap or into a buoy etc. Everything else will result in random data.
                                        DMytroD V 2 Replies Last reply Reply Quote 3
                                        • DMytroD Offline
                                          DMytro @Egika
                                          @egika said in Swimming GPS accuracy of Suunto 5:
                                          Ah cool, funny way to think about it like that, that’s for sharing!
                                          • A Offline
                                            ActiveJiggy
                                            Is the GPS accuracy setting set to best? It’s also possible to combine navigation systems.
                                            freeheelerF 1 Reply Last reply Reply Quote -1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
