    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Running, cadence, and too little steps. Please share your data
    Scheduled Pinned Locked Moved Suunto 5
    runningcadencesteps
    22 Posts 9 Posters 5.9k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • juhis70J Offline
      juhis70
      Running duration, cadence, and steps are linked together like this:
      If you run 10 minutes with average cadence 85 rpm, you get 1700 steps. Because 85 revolutions per minute equals 170 steps per minute (spm), and 10 minutes of that gives 1700 steps.
      Problem: When I run, my Suunto 5 always reports less steps for the run than calculated from the average cadence and duration gives.
      My last 6 runs:
      My watch gives me way too low running cadences, but even calculated using those cadences, the steps that watch gives are lower, typically 10–20%.
      Unfortunately I have only this somewhat broken data, as my cadence is incorrect, too. So I don’t know how big the difference between calculated steps and steps from “steps engine” is, when cadence is right.
      So please give some of your running data! Duration, cadence, and steps.
      If (way) too little steps are systematically reported during running, I suggest that the watch (or watches; maybe other models, too) would calculate step count also from duration and cadence. If this calculated step count is higher, use it, if not, use the step count from “steps engine” (or whatever that is called).
      suzzloS Anna MorralA 2 Replies Last reply Reply Quote 1
      • suzzloS Offline
        suzzlo Moderator @juhis70
        @juhis70 just my last run
        Distance: 16k
        Time: 1:34h
        Cadence: 79
        94min x 79 x 2 = 14852. The watch (+stryd) reported 15249
        I hope this helps
        Suunto: Race, S9Peak, Spartan Sport Wrist
        Garmin: FR745, Edge 530
        SA topics:
        • Guides - https://forum.suunto.com/tags/guides
        juhis70J 1 Reply Last reply Reply Quote 0
        • juhis70J Offline
          juhis70 @suzzlo
          @suzzlo Thank you! I guess Stryd gives very accurate step count (and it overrides the step count from wrist). I think the ~400 step difference is not much at all. That is much more valid data than I get from my watch, although you have the Stryd which may affect things.
          L 1 Reply Last reply Reply Quote 0
          • L Offline
            LGoSo @juhis70
            @juhis70 I already reported a similar problem and I think it is, at least, a discrepancy (https://forum.suunto.com/topic/6306/stride-frequency-discrepancy). I am always running with two watches: S5 (with Stryd) and Coros Pace (with pod). My cadence values from the Stryd (on S5) and from my Coros are always the same. The cadence value estimated from the steps on S5 divided by time are always lower than the value from Stryd and Coros.
            My last run:
            Stryd (on PowerCenter): 41:29h (moving time 40:50h) 6.81km 173spm
            S5 (on SA): 41:28h 6.81km 87rpm (174spm) 6915steps
            Coros: 41:29h 6.82km 173spm
            With the steps from S5, the cadence is 167spm or 169spm depending if you take the moving time or wall clock time. Anyway it is lower and, for this run, it is quite acceptable (~4spm difference). But the difference can be higher as showed in my other post (10 spm difference and even higher on other runs). And always lower. But for suzzlo, the cadence from the steps is higher than the one reported in SA.
              Dimitrios Kanellopoulos Community Manager
              Hi guys. Steps are coming from a different source than cadence. Unfortunately. Let’s seperate those concerns.
              Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
              suzzloS 1 Reply Last reply Reply Quote 1
              • suzzloS Offline
                suzzlo Moderator @Dimitrios Kanellopoulos
                @dimitrios-kanellopoulos 🤔 are not both comming from our feets?
                (sorry) 😆 😆 😆
                SA topics:
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                  Dimitrios Kanellopoulos Community Manager @suzzlo
                  @suzzlo s5 for example has a context engine that detects what you are doing. Will count less steps ie if dishwashing etc.
                  juhis70J 1 Reply Last reply Reply Quote 2
                  • L Offline
                    lorenzo12375 Bronze Member
                    Under Armour machina 2
                    • juhis70J Offline
                      juhis70 @Dimitrios Kanellopoulos
                      @dimitrios-kanellopoulos So in my case the context engine fails to detect I’m running, although I’ve told the watch I’m running and the watch detects my pace is < 6/km. Does watch “tell” (pass, whatever) the context engine that I’m running, and/or my speed/pace?
                      Because if I would really run 10.9 km with only 6000 steps, my one step length would be 1.8 meters, and stride length would be 3.6 meters! That is totally unreal!
                      We don’t have to mix cadence and steps, but if another of them gives unreal results, then the watch could use better values from the other.
                      I’m also starting to believe that also this second watch is somewhat broken, as I get so weird (wrong) values. From apparently two separate systems (cadence and steps). And I would just like to run, not “fix my watch”…
                      EgikaE Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                      • EgikaE Offline
                        Egika Platinum Member @juhis70
                        @juhis70 said in Running, cadence, and too little steps. Please share your data:.
                        I think this is an interesting topic and good finding.
                        Am following.
                        The good thing is, that you don’t need a watch to just run. 👍
                          Dimitrios Kanellopoulos Community Manager @juhis70
                          @juhis70 well what I mean is the cadence uses the raw sensor data (frequency) to produce cadence and steps come from another input.
                          • juhis70J Offline
                            juhis70
                            For the last weeks I’ve focused on running. Ran over 200 km in June, that’s my new one month record. 💪
                            OK, the cadence AND steps counter are broken, even if I did have strange arm movement. And I can assure you it is not that strange, normal balanced running when I’ve watched video of my running. We’ve all seen a running person with funny arm movements, but I’m not that.
                            Steps
                            All runs report nearly only half of the steps, ranging from 51 % to 57 %. This error is not linked to cadence error, their relation/ratio is not constant. Example 11.4 km run 2.7. (July 2nd): Suunto 5 steps 5860, correct steps more like 11400 steps.
                            Also when the watch is in my hand not in excercise mode, it misses a lot of steps. Thousands a day.
                            For example, yesterday I ran 3.6 km and walked 6.6 km. Me running 3.6k is around 3.6k steps. Walking 1 km equals at least 1200 steps. After 3.6 km + 6.6 km (and daily activity, which produces 1000-3000 steps at least) step count was around 9500, should have been at least 11500 steps (3.6k+6.6k x 1.2). Plus daily activity steps.
                            Running cadence
                            I’ve had two Suunto 5 watches. With the first one I noticed, that the cadence value “jumps” between correct values (rpm) and exactly half of the correct values. My running cadence is usually between 80 and 100, average for a run is around 87 rpm. So the values jump between 40…50 and 80…100. There are no random values, or “between” values (of course some “noise” in the data).
                            This of course ruins the cadence graphs, and average cadences. The more the cadence locks to ½ value, the lower the avg cadence. I’ve had avg cadence values 60–71 with the first watch, and 59–65 with the second watch. So the value is useless.
                            After about 7 runs I sent the first watch to service. They replaced it with a refurbished one. That did not make the problems go away. Actually, this second watch locks more to half cadence than the right value compared the the first watch, so the avg cadence values are lower. Also the step counting is worse (fields “step x” and “cad x” in the data, the higher the worse)
                            The Data
                            Maybe it speaks for itself 🙂
                            Graphs
                            To prove the watch is really alternating between correct cadence and half cadence, and not just throwing some random cadence values, I can reconstruct good cadence graphs from excercises .FIT file by going through the cadences, and just multiplying the half cadences by two. (I have an OpenOffice calc sheet with macros to automate this.)
                            Here’s 25.6. run, cadence graph from Suunto App:
                            And here is (from .FIT) reconstructed cadence graph, green line is the corrected cadence, and blue line is a moving average that cuts the biggest spikes:
                            Suunto 5 avg cadence 63 rpm, correct avg cadence 87 rpm.
                            My right arm has maybe “sharper” movements, so the watch picks the right cadence and cadence graph is better, but not perfect. Here’s a 2.4 km test run in 28.6. (the longest run with watch in my right hand):
                            Suunto 5 avg cadence 82 rpm, correct 87. That’s almost good. But the steps, Suunto 5 counted 1338 steps, should be around 2400 steps 😄
                            • juhis70J Offline
                              juhis70
                              “Funny” thing about the bad steps counter in my watch: while walking, if I go to the watch screen that shows the steps, the step count increases every step (sometimes there is a lag at beginning, then it adds several steps). It does not any skip any steps, even when I hold my arm in front of me looking at the watch (i.e. not waving arm). That is nice, almost like magic.
                              But when the watch is not in the “steps screen”; it apparently doses off occassionally and forgets to count the steps while I’m walking. This is not nice.
                              AaurakkioA 1 Reply Last reply Reply Quote 0
                              • AaurakkioA Offline
                                Aaurakkio @juhis70
                                hei @juhis70 ,
                                wierd thing you are facing there.
                                On my watch the measures correspond quite nicely and the steps from watch are just slightly below the calculated by cadence (see 5 random activies from last 6 weeks):
                                FYI, I keep my S5 on inside left wrist and constantly on the default view (during the activities).
                                Given the information, I wonder whether your issue could be either:
                                1. something defective in your specific watch; or
                                2. how you hold the watch and how you move your arm.
                                ES: "Caminante, no hay camino / Se hace camino al andar."
                                EN: "Wayfarer, there is no way / The way is made by walking."
                                • juhis70J Offline
                                  juhis70 @Aaurakkio
                                  @aaurakkio Hi, thanks for your reply and data. Your values are really accurate, I’d “buy” that, unlike my tens of percents wrong step counts. I don’t think my arm movement is very uncommon, my previous activity bracelet counted (can still count) my steps very precicely. And S5 can count steps even when I hold the watch in front of me and look at the step counter. It starts failing only when I’m not observing it…
                                  • Harald VärsH Offline
                                    Harald Värs
                                    My wife bought the S5 few years ago and end up frustrated because she felt that no matter how much she moved during normal day she could barely get the activity/steps for the day. That felt quite odd and we changed watches (my polar to shes S5). I experienced same problems but didn’t have time to investigate any further. Now I had a change to compare directly 2 devices at the same time with Oura ring and picture shows that our earlier experiences might have some truth behind them. Now I fount this thread after searching similar cases online and feel like there might be some correlation here with @juhis70.
                                    • EgikaE Offline
                                      Egika Platinum Member @Harald Värs
                                      @harald-värs maybe no correlation. Your numbers should rather be the interpretation of steps.
                                      Oura counting every single foot and Suunto the cadence (left+right foot)
                                      Harald VärsH 1 Reply Last reply Reply Quote 0
                                        Harald Värs @Egika
                                        @egika Fair point, thank you.
                                        Does anyone know then if Suunto is one of few that counts steps like this, because I’ve used to measure healthy active day around 10k mark on steps and what devices I’ve used in past are somewhat on par with data that Oura gives here. Seems just little weird for me, that’s all.
                                        Sorry going little off topic here.
                                        juhis70J Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                        • juhis70J Offline
                                          juhis70 @Harald Värs
                                          @harald-värs Thanks for your reply. Steps are single foot steps in Suunto’s world, too. Every step is/should be counted.
                                          When talking about cadence, Suunto uses revolutions (right + left foot) per minute (rpm), while many others use steps per minute (spm). Some think that ideal running cadence is 180 spm, or 90 rpm.
                                          If Oura counts the steps correctly, there’s definitely something wrong with also your S5’s steps. At about same ratio as in mine, my S5 counts around 60 % of my steps (running and walking).
                                            Dimitrios Kanellopoulos Community Manager @Harald Värs
                                            @harald-värs Suunto 5 and Suunto 3 only have a context engine that doesn’t over count steps from washing dishes or tapping on the floor with your legs or typing. Others will. Including oura.
                                            Harald VärsH 1 Reply Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
