    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Transferring activities
    Scheduled Pinned Locked Moved Suunto 9 Peak
    22 Posts 12 Posters 8.2k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • I Offline
      IoWBoy
      Hi. I’ve just ordered a 9 Peak. This will be my first Suunto watch. I currently plan to still use my Garmin Edge 530 for off road cycling. Is there a way to transfer my cycling activities to the Suunto app (I use an iphone)? Thanks in advance for any suggestions.
      freeheelerF cosme.costaC pavel.samokhaP ? Brad_OlwinB 5 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @IoWBoy
        @iowboy
        check out www.quantified-self.io (QS) you can connect your garmin account (GC) and your suunto app account (SA). activities from both accounts will show up there. but it is not a classical sync, tool. what you can do is sending activities from QS to SA.
        It is meant to be a one by one thing.
        Maybe you want to use QS as your main database since you are using 2 devices from 2 different suppliers. I would recommend it as the cleanest and easiest solution.
        living sideways
        I 1 Reply Last reply Reply Quote 0
        • I Offline
          IoWBoy @freeheeler
          @freeheeler Genuine thanks. I hadn’t come across this app before.
          EgikaE 1 Reply Last reply Reply Quote 1
          • EgikaE Offline
            Egika Platinum Member @IoWBoy
            @iowboy actually QS is not an app, it is a web service.
            You could also upload your .fit files exported from Garmin Connect to the Suunto data base using QS as an upload service.
            But it is more manual work.
            The sync tools out there are still not using the proper Suunto api and upload data in a way that there are issues with altitude etc.
            freeheelerF 1 Reply Last reply Reply Quote 1
              freeheeler @Egika
              @egika
              true… the transition from Garmin to Suunto was easier back in MC days
              living sideways
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                Dimitrios Kanellopoulos Community Manager @freeheeler
                @freeheeler how if I may ask? Back then there was not any import api
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                  freeheeler @Dimitrios Kanellopoulos
                  @dimitrios-kanellopoulos
                  uff… you’re challenging my old grey cells… 😉
                  I’ve had Garmin Connect synced to MC thru SyncMyTracks? Or was it another service? I remember I could activate it but never really got rid of it afterwards.
                  I made sure before I bought my first A3P that I can keep my old and dusty Garmin files
                  living sideways
                    @freeheeler for sure we didn’t support FIT File import. So perhaps some workarround could have existed. Idk as well. But if no FIT file that also means no ascent etc
                    • cosme.costaC Offline
                      cosme.costa @IoWBoy
                      @iowboy Nowadays I have the same combination that you will have, except I have a S9Baro instead of the Peak.
                      In QS you can download automatically the activities from Garmin but to have them in SA you have to upload the fit file, one by one, in QS too. I do it every time I finish my ride, not big deal to me because I only do one ride per week, if I would do more rides I probably would have given up on uploading to SA, despite the fact that I like much more SA than Garmin Connect.
                      I 1 Reply Last reply Reply Quote 1
                        I did the transition mid November 2017. The upload to QS was done from SA only. With previously sync MC to SA of course.
                        living sideways
                        • pavel.samokhaP Offline
                          pavel.samokha @IoWBoy
                          @iowboy don’t listen anyone here and use RunGap (it will cost something like $1 per month)
                          Opinions expressed are solely my own and do not express the views or opinions of my employer
                          freeheelerF EgikaE ChrisAC 3 Replies Last reply Reply Quote 3
                            freeheeler @pavel.samokha
                            @pavel-samokha
                            😂 it’s a question about the “religion”… like apple or android 😉
                            living sideways
                            pavel.samokhaP 1 Reply Last reply Reply Quote 0
                            • EgikaE Offline
                              Egika Platinum Member @pavel.samokha
                              @pavel-samokha 🙂
                              I think it is only iOS…
                              Does it get all your data right into the SA servers?
                                pavel.samokha @freeheeler
                                @freeheeler the topic starter mentioned he uses iPhone
                                Android users may try FitnessSyncer, it uses proper API
                                Mff73M suzzloS 2 Replies Last reply Reply Quote 3
                                • Mff73M Offline
                                  Mff73 @pavel.samokha
                                  @pavel-samokha
                                  i may have tried fitnessSyncer in the past, and i have given up (i don’t remember why 😞 )
                                  i will give it a new try 😉
                                  Thanks.
                                  SSU (retired), SV1, SV2
                                  Wife : S9PP
                                  SA: Always the latest beta :)
                                  Android + Galaxy S205G
                                  • ? Offline
                                    A Former User @IoWBoy
                                    @iowboy Second vote for RunGap. Yes, it’s not free, but it costs peanuts and syncs everything perfectly. The developer is also super-responsive.
                                    You can also wear your Peak while cycling and capturing rides there, in addition to bike computer. Technically, the watch will probably be on your arm anyway.
                                    • Brad_OlwinB Offline
                                      Brad_Olwin Moderator @IoWBoy
                                      @iowboy If you have an iPhone and use RunGap you will be able to sync between both Garmin and Suunto with your bike computer syncing to Suunto, the Peak syncing to Garmin so you will have all data on both platforms! Once you set up the syncing, it is automatic and very nice.
                                      Vector/T6c/Vertical 2 Ti
                                      I ? 2 Replies Last reply Reply Quote 3
                                      • suzzloS Offline
                                        suzzlo Moderator @pavel.samokha
                                        @pavel-samokha said in Transferring activities:
                                        Good to know. I don’t recommend using Sync My Track. Don’t use proper API, loose some data…
                                        BR
                                        Suunto: Race, S9Peak, Spartan Sport Wrist
                                        Garmin: FR745, Edge 530
                                        SA topics:
                                        • Guides - https://forum.suunto.com/tags/guides
                                        • ChrisAC Offline
                                          ChrisA Platinum Member @pavel.samokha
                                          @pavel-samokha Fully agree! Run gap is great works flawlessly and cost is very reasonable. I can highly recommend it!
                                          Currently Race I
                                          • I Offline
                                            IoWBoy @Brad_Olwin
                                            @brad_olwin Thanks for this info. I didn’t think it would be so easy. Great news.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
