    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    How to import move with ascent
    Scheduled Pinned Locked Moved Suunto app - Questions & Feedback
    31 Posts 7 Posters 1.2k Views
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R Offline
      Remrem
      Hello, I cannot correct the registration errors on my watch.
      I have several moves, with inconsistent elevation values.
      I tried to correct the moves by uploading the .fit file with the application. Then as indicated in this forum, I tried to modify it with Land, Iphigénie, VisoRando. Then re-import it via SportTracker.
      But each time the move does not contain a difference in height.
      Thanks in advance.
      Have a good day.
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Remrem
        @remrem you can import FIT files using quantified-self.io
        Watch: Suunto Vertical Ti
        Blog: isazi's home
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          Remrem @isazi
          Thank you for your reply.
          I have connected quantified-self.io to my Suunto account.
          Next, I tried to edit the inconsistent value of a move’s ascension and re-import a modified .fit file.
          This without results in the Suunto app.
          It’s really heavy this lack of functionality of the Suunto app!
          • isaziI Offline
            @remrem I meant you can use QS to import FIT files to SA, but you need to edit the FIT file somewhere else.
            Blog: isazi's home
            • R Offline
              Remrem @isazi
              @isazi said in How to import move with ascent:
              Yes. Of course. That’s what I did…
              • isaziI Offline
                @remrem if you want you can post here the file and I (or someone else) can try.
                Blog: isazi's home
                • R Offline
                  Remrem @isazi
                  @isazi I think it takes a long time to sync all the moves.
                  It is not finished because the moves appear gradually in Quantified Self.
                  • isaziI Offline
                    @remrem it does take time to sync past moves, but you don’t really have to do it if you just want to upload something to SA. Just connect QS to Suunto, have your edited FIT file (using what you said before “Land, Iphigénie, VisoRando”), and click here
                    you can then select the file on your computer and the activity will end up on Suunto App.
                    Blog: isazi's home
                    • R Offline
                      Remrem @isazi
                      @isazi : Hello,
                      I modified the .fit file.
                      I then imported it into QS.
                      But no activity is added to my account.
                      Thanks.
                      • isaziI Offline
                        @remrem with no error from QS?
                        Blog: isazi's home
                        • R Offline
                          Remrem @isazi
                          @isazi : I just have the message : “Processed 1 file”
                          isaziI Mff73M 2 Replies Last reply Reply Quote 0
                          • isaziI Offline
                            @remrem then refresh Suunto App, the activity should get there.
                            Blog: isazi's home
                            • Mff73M Offline
                              Mff73 @Remrem
                              @remrem said in How to import move with ascent:
                              if fit file is not “perfect”, following fit sdk rules, it may happen. QS is able to process it, but SA doesn’t accept it, but without an error return (to QS).
                              Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                              Suunto Vertical all black
                              Wife : S9PP
                              SA: Always the latest beta :)
                              Android 13, Galaxy S205G
                              R 1 Reply Last reply Reply Quote 1
                              • R Offline
                                Remrem @Mff73
                                @mff73 said in How to import move with ascent:
                                So how do you modify .ift files so that they are accepted?
                                How complicated it is when before it was so easy with MovesCount! When will a real update of the application be made?🙄
                                Mff73M 1 Reply Last reply Reply Quote 0
                                • Mff73M Offline
                                  Mff73 @Remrem
                                  Personally, and really personnaly, i modify them manually (decode fit to csv, edit and recode).
                                  it is long and not convenient, but i know what is inside. I was hoping to use other tools like you to crop, change field like altitude, HR, etc…, but export is not perfect as well. So need to also tweak it manually.
                                  It is not really Suunto’s fault, as they seem to follow strictely the fit sdk feature, it is more these softs that not export totally according to this (from my personnal findings).
                                  There are many posts in this forum, requesting crop feature/ascent edit, etc… directly in Suunto’s ecosystem, i would vote for them, but editing fit files : i find it not so easy.
                                  Wife : S9PP
                                  • R Offline
                                    Remrem @Mff73
                                    I tried to modify them manually but without success.
                                    How do you do ? Do you change every point?
                                    Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                    • Mff73M Offline
                                      Mff73 @Remrem
                                      @Remrem
                                      Download fitsdk from Web, find fitcsv tool in it and read and learn how it works, how fit files are structured.
                                      Decode fit file into csv, find total_ascent message and change value and recode csv to a fit file, and pray 😊.
                                      But not very convenient for sure, and maybe long journey to learn this and discover all issues that may happen after bad file modification.
                                      If someone has a real other working solution, I also take it 😊.
                                      Wife : S9PP
                                      • Brad_OlwinB Offline
                                        Brad_Olwin Moderator @Remrem
                                        @remrem I have had luck with this set of tools. https://www.fitfiletools.com/#/top
                                        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing
                                        • R Offline
                                          Remrem @Brad_Olwin
                                          @brad_olwin said in How to import move with ascent:
                                          Thanks for your review.
                                          However in the tools none allows to modify the ascent.
                                          • R Offline
                                            Remrem @Mff73
                                            @Remrem
                                            Decode fit file into csv, find total_ascent message and change value and recode csv to a fit file, and pray .
                                            If someone has a real other working solution, I also take it .
                                            Thanks for your response.
                                            Fortunately Garmin is developing tools !! 😠
                                            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
