    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Heart rate is wrong in 2km first!
    Scheduled Pinned Locked Moved Suunto 5
    24 Posts 10 Posters 4.9k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • hieusH Offline
      hieus
      Hi Everyone,
      I have been using Suunto5 for 1 month. When i ran, my heart rate was often wrong in 2km first (usually zone 5).
      BD035329-08A4-40B9-B7D7-0B514E30024F.jpeg 6DD6D852-2B50-4C3B-B8CF-C78DC8BD07ED.png
      I dont know why? Please help me!
      Many thank!
      • isaziI Offline
        isazi Moderator
        I don’t have a 5, but do you wait until you get a good read? I usually wait a bit longer than the icon getting green.
        Blog: isazi's home
        hieusH 1 Reply Last reply Reply Quote 0
        • hieusH Offline
          hieus @isazi
          @isazi i alway wait for ready ( heart icon and gps icon are green) and then ran.
          J 1 Reply Last reply Reply Quote 0
          • EgikaE Offline
            Egika Platinum Member
            How are you wearing the watch? Loose or tight? Where on the arm? Hot or cold weather?
            • J Offline
              jw cou Silver Members @hieus
              @hieus try staying on the ‘start’ screen (when you get the gps and heart locks) for a couple of minutes, i.e. from when you put your shoes on instead of when you’re out. I had the same issue than you (with a S9 though), and that solved it
              hieusH 2 Replies Last reply Reply Quote 2
              • ? Offline
                A Former User
                I had the exact same behaviour with an Ambit3 and HR strap, I presumed that the strap is starting to fail, but this is interesting if you get the same with optical sensor too. Now I’m confused: maybe my strap isn’t failing (I need to measure the resistance then) and something strange is happening when data is interpreted by SA?!
                • Łukasz SzmigielŁ Offline
                  Łukasz Szmigiel
                  If you don’t see something like this after you take your watch off, it’s too loose.
                  Also, as others mentioned, have ohr on (workout start screen) during your preparation, warmup, etc. 5 minutes before hitting “start” should be enough.
                  Shaving wrist also helps but for some people it’s too hardcore 😉
                  S9PP 2.50.28
                  • ? Offline
                    A Former User @Łukasz Szmigiel
                    @Łukasz-Szmigiel I guess then I need to shave my chest 🤣
                    Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 2
                      Łukasz Szmigiel @Guest
                      @andrasveres yeah I’ve heard about some furry runners that have problems with chest straps but I was referring to the original poster 😉
                      As with hr strap - I’d check the battery first or maybe the belt is worn out.
                      S9PP 2.50.28
                      • ? Offline
                        @Łukasz-Szmigiel Just kidding. 😉
                        Regarding the strap: battery change was the first thing done, with no result. Planning to buy a Polar H10 as Suunto straps tend to start fail in no time.
                        Sorry for the off topic.
                        • hieusH Offline
                          hieus @Egika
                          @Egika said in Heart rate is wrong in 2km first!:
                          Where on the arm
                          I wear it on my left wrist and tight, the weather is so hot (Hanoi, Vietnam weather)
                          • hieusH Offline
                            hieus @jw cou
                            @jw-cou yep, i will try with your tip.
                            • Stefan KerstingS Offline
                              Stefan Kersting Platinum Member
                              Had the same experience too. Have a Ssu and have to use hr belt. If you want a precise measurement use a hr belt. I had 2 suunto hr belts and - excuse me - they are rubbish. Suunto can’t that. So I bought a H10 and I’m pretty satisfied. No problems at all. It’s worth the money if you want reliable hr data
                              Instagram: https://www.instagram.com/helgelandsbukken/
                              https://www.instagram.com/suunto_adventures/
                              IG: Helgelandsbukken, suunto_adventures
                              Vimeo: vimeo.com/helgelandsbukken
                              Blogg: https://turblogg.midnattsola.com
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                Dimitrios Kanellopoulos Community Manager @Stefan Kersting
                                @Stefan-Kersting there are new belts and improved ones though. If you still have a warranty ask for a replacement. They are white on the sensor buckle.
                                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                Stefan KerstingS 1 Reply Last reply Reply Quote 0
                                  Stefan Kersting Platinum Member @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos ok then my comment applies just the older ones. Don’t have experience with the new ones. I don’t have warranty any more but happy with the polar 😊
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                    @Stefan-Kersting I know pal, just saying 😄
                                    lexterm77L 1 Reply Last reply Reply Quote 1
                                    • lexterm77L Offline
                                      lexterm77 Bronze Member @Dimitrios Kanellopoulos
                                      New belts have a different problem, they evaporate quickly from suunto store.
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 3
                                        Dimitrios Kanellopoulos Community Manager @lexterm77
                                        @lexterm77 yes and manufacturing is slow due to Corona. Difficult times for EU factories etc
                                        lexterm77L 1 Reply Last reply Reply Quote 0
                                          I bought two just in case this coronaverse shit hits the fan.
                                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                            @lexterm77 🤙
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
