    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issues with V02 Max registration Suunto 9
    Scheduled Pinned Locked Moved Suunto app and other software services
    27 Posts 7 Posters 3.0k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      filipsvensson92
      Hi.
      Since I got my Suunto 9 like 6 weeks ago it haven’t been able to register any V02 max data. When I get to the icon and pushes the button it is just an overall description regarding what V02 is, even though I’ve registered a lot of running exercises. Any one with the same problem?
      /Filip
      Saketo NemoS 1 Reply Last reply Reply Quote 1
      • Saketo NemoS Offline
        Saketo Nemo Moderator @filipsvensson92
        @filipsvensson92
        Are hr data present and reliable? considers that the data, as far as I know, is returned only if it can be considered reliable. you also adjusted your heartbeat at rest and maximum, on your 9
        freeheelerF F 2 Replies Last reply Reply Quote 0
        • freeheelerF Offline
          freeheeler @Saketo Nemo
          @Saketo-Nemo
          is VO2max absolute or relative to bodyweight?
          just had a discussion about this topic with an expert because I was worried of my values of around 36-37 VO2max during running and hiking… with these values the watch makes me 19 years older than I actually am.
          all metrics setup correctly and HR measured reliably with chest strap
          living sideways
          Saketo NemoS 1 Reply Last reply Reply Quote 0
            Saketo Nemo Moderator @freeheeler
            @TELE-HO
            yes, as far as I know, the Vo2 value correlates with body weight.
            Just for science, and to understand each other. I know that you are an strong skier, you probably have a very developed Z3, what data do you have? Do you also run? I do also skimo, but the values it gives me are lower than those of running.
            I am 37 years old, weight 76kg, I run 5km at about 4’15 "per km and I have 53.6 of Vo2.
            I know that for Vo2, while intent as the maximum value, it should be calculated even if you practice sport at a lower intensity, but for what has been my experience so far, the greatest values I reach precisely with running.
            freeheelerF 1 Reply Last reply Reply Quote 1
              @Saketo-Nemo
              well, I don’t consider myself as a strong skier. I love skiing but this season I could not maintain my fitness due to injury…
              I cycle (road and mtb), I sometimes run and I do skitouring.
              My metrics are definitely different to yours: 37 years, 1.74m and 97kg… most of it bones and muscles 😉 …and my VO2max is as mentioned at 36-37. I normally go to the forest for running and normally have something like 6:30 / 7:00 /km.
              When I hike uphills I can do around 700m/h but this depends on the topography of course.
              edit: what is Z3? the HR zone?
              living sideways
                @TELE-HO
                On the way up I believe that the data cannot be trusted in any way if you don’t consider it, I don’t say the topography, but at least the weight of the equipment.
                So, by estimate, making the due proportions, even with my friends, I think the value is quite underestimated. However, if I tried to run maybe 3 or 4 times for those 20 minutes, in my opinion the watch would give you something higher (but above all, reliable)
                  @Saketo-Nemo
                  you mean if I go for shorter runs the values should be different?
                  I sometimes suspect that VO2max is dropping while PTE goes towards and beyond 5… but did not verify that yet
                  living sideways
                  isaziI Saketo NemoS BulkanB 3 Replies Last reply Reply Quote 0
                  • isaziI Online
                    isazi Moderator @freeheeler
                    @TELE-HO do some intervals, or some half hour runs with some sprints.
                    Blog: isazi's home
                      @TELE-HO
                      no, I didn’t want to lead you to short races … but just to run 🙂
                      Sport where in my opinion the value is closer to the truth
                        @Saketo-Nemo
                        @isazi
                        thanks guys, I’ll try that.
                        Maybe this makes me younger 😉
                        Of course it’s an algorythm calculating the fitness age and not sensors measuring exhale air quality vs HR etc… but it still kept me thinking the past few weeks when my watch told me I was 56 years old.
                        I know I’m always the slowest uphills when we do our annual way from Airolo over Gotthardo back home… but I’m always slipstreaming my friends home at the end of the day… 🤷
                        🤞 I’ll do some running this week to figure this out 🙂
                        living sideways
                        • M Offline
                          MoveOrRust
                          I’ve been trying to figure this out as well as my fitness level and fitness age are grossly inaccurate on my Suunto 9. As best as I can determine VO2 max outside the lab is determined off of the heart rate and is related to your weight to give you the value of millilitres per kilogram. A normal male athlete would have a range of 40 to 80 millilitres per kilogram for vo2max. So the only measured metric that Suunto is using is your heart rate, and the heart rate recording is considerably inaccurate off the wrist sensor and marginally better using a heart rate strap. I do a lot of biking and cross-country skiing and I find my heart rate recordings are all over the map. That’s far this data is not been useful to measure any kind of progress with training.
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Online
                            isazi Moderator @MoveOrRust
                            @MoveOrRust I get similar VO2MAX on Garmin and Suunto, and have few reasons to doubt the HR reading with the chest straps I own (although I can spot the errors with the wrist ohr sensors).
                            Blog: isazi's home
                            M freeheelerF 2 Replies Last reply Reply Quote 1
                            • M Offline
                              MoveOrRust @isazi
                              @isazi , yeah I’m not sure what’s going on, same heart rate strap on my Garmin and I get a different heart rate recording than using my Suunto 9.
                                freeheeler @isazi
                                @isazi
                                when I do warmup before physiotherapie I sometimes compare OHR to the cardio machines HR measured on the handlebars and they are pretty similar. I think with the chest strap it would be almost equal.
                                That’s why I think my chest measurements are close to very accurate in any situation.
                                living sideways
                                  As far as I know, neither sport is contemplated by Firstbeat in the calculation of Vo2, I think because of too many variables that invalidate the calculation, which is already complex.
                                  talking about “normal” athlete between 40 and 80 seems excessive to me, given that Kilian has 89 😄
                                  Wrist heart rate reading is subjective, but the strap normally works well (yes, when it works: -d)
                                  The data are not only affected by heart rate, but by resting and maximum beats, age and weight.
                                  Also I believe that, sorry if I insist, in the run, at least the flat one, the values are as close as possible to reality as the variables are greatly reduced,
                                  • BulkanB Offline
                                    Bulkan Moderator @freeheeler
                                    @TELE-HO Firstbeat algorithms love tempo run and intensity. I think 50 aerobic 30 tempo 20 above zone 4 is what they love.
                                    If you have a heavier in your weight than the medium or you are doing base the VO2max will be lower.
                                    Another example if you do polarized training the algorithms of first beat are useless.
                                    Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                                    • F Offline
                                      filipsvensson92 @Saketo Nemo
                                      @Saketo-Nemo my HR works fine so thats not the issue. The screen with V02 just looks like it did from
                                      The beginning when I started the watch for the first time, even though I’ve registered a lot of different exercises. Running, power walking, swimming, CrossFit etc…
                                      • isaziI Online
                                        isazi Moderator @filipsvensson92
                                        @filipsvensson92 you need just running for VO2, the other exercises do not contribute, and walking will provide you VO2MAX levels only after the algorithm is working. Did you have some half a hour or so runs, with effort in different HR zones? Did you setup your zones, or at least max and resting heart rate?
                                        Blog: isazi's home
                                        • F Offline
                                          filipsvensson92 @isazi
                                          @isazi @isazi ok. I’ve been running for 20-30 minutes or so. Only indoor running on a treadmill though. I have set up max HR and reating HR. I haven’t sat up any zones though, can this be the issue?
                                          Saketo NemoS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                            @filipsvensson92
                                            I think u have to run under gps, not on a tapis 😉
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
