    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Baro football run distance in km
    Scheduled Pinned Locked Moved Suunto app and other software services
    28 Posts 5 Posters 4.1k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      Alexbg
      Hi, I have Suunto 9 Baro for a month already. I’m using the watch mainly to track my sports activities. For cycling and running the GPS tracking is fine, not perfect but fine. The big disappointment for me was the tracking during football exercise. For one hour of football training the watch tracked around 8,500 steps and only 3km running distance. I’m 1.82m tall, so it will be hard for me to run/sprint with a 0.35m steps. The interesting thing come when I start analyzing the tracks in Suunto app. It appears that the GPS track makes a point not every second, but with a random frequency, sometimes even more than 30 seconds. I always synchronize my watch before training to get the latest GPS positioning. In additional I always wait to get a signal before starting exercise, even in football exercise intentionally wait for a minute or two after getting GPS signal before exercise start. Always put the watch on performance mode (in performance mode GPS refresh rate should be 1 second). I also tried different GPS settings, GPS only, GPS+Galileo, GPS+GLONASS without success.
      Please share your experience.
      Am I doing something wrong or Suunto watches are not made to track football activities, i.e. activities where you run in “box” field like tennis, basketball or football?
      freeheelerF 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Alexbg
        @Alexbg
        suunto is made for the highest mountains and the deepest oceans… no one mentions the greenest soccerfield 😉
        what FW do you have installed? and could you make your activity public and share it?
        I think the tracking has improved a lot since the FW update, but it really depends also on buildings around the stadium
        living sideways
          freeheeler @Alexbg
          @Alexbg
          check this out: between km 3 and 4 I ran around a tree and even with new FW the watch did not recognize it.
          I think the S9B chip is less sensitive than the one from A3PS… but therefore might use less energy which is good for most mountain sports but not ideal for field sports.
          https://quantified-self.io/user/jBm0qOhihUMykVYD8HBJMshQrJc2/event/A60PtzTC8ofZ20ZyQpqZ
          living sideways
          • A Offline
            Alexbg
            Here is a link to my latest football training: https://www.sports-tracker.com/workout/alex840541/5dd6c2eca65c74d6bd478d7c
            If Suunto made the watch only for the highest mountains, they SHOULD NOT commercial it as a watch with 80 sports activities!!! 😉
            Simply can delete 79 of them and leave only mountain running 😉
            freeheelerF 1 Reply Last reply Reply Quote 0
              freeheeler @Alexbg
              @Alexbg
              SA and the watch also say 3km?
              living sideways
              • A Offline
                Alexbg
                Yes, Suunto App and the watch also say 3km. Latest software is installed. Done reboots several times. Read everything available on the net on GPS refresh timing and GPS accuracy. Didn’t found a solution so far.
                By the way even in other sport modes (running/cycling) GPS refresh rate never has been 1 second despite always using performance mode.
                  freeheeler @Alexbg
                  @Alexbg said in Suunto 9 Baro football run distance in km:
                  how can you look this up? I don’t find this and I always use performance with GPS only.
                  soccer with distance vs steps is hard for me to tell, but it is a sprint sport with small steps between. i can imagine from what i know about S9B accuracy so far that it is hard to handle soccer for the watch.
                  living sideways
                  • A Offline
                    Alexbg
                    On GPS refresh rate - I’m looking at the graph in Suunto App or Sports Tracker and check time difference between points on the map. Is there other way to do it?
                    On the Suunto 9 Baro GPS accuracy it is a shame that top Suunto product find it difficult to perform. Have a friends with competitor sport watches and one of them with Suunto Spartan Ultra. All of them tracked approximately same amount of steps as me, but higher run distance between 5 and 6 km. It is strange how Spartan Ultra works fine, but Suunto 9 not.
                    Don’t get me wrong. I’m trying to help Suunto.
                    freeheelerF 2 Replies Last reply Reply Quote 1
                      freeheeler @Alexbg
                      @Alexbg
                      I never use sports tracker… it is not correct for altitude values and has actually nothing to do with SA…
                      I’ll check SA for the refresh rate.
                      I see it as a challenge for watch makers to setup a watch that does the split between long batterylife, high accuracy and no nervous track recording. but this should be a default setting for each sportmode…
                      living sideways
                        freeheeler @Alexbg
                        now I saw it on my latest activity when i zoomed in extremely on the graph… one point every 4 seconds… but sometimes also every second. seems to be dynamic
                        living sideways
                        • A Offline
                          Alexbg
                          Yes, Suunto said it should refresh GPS every 1 second on performance mode! That is how they commercial the product.
                          Based on my experience using the watch for running, cycling and football the watch GPS refresh rate varies between 1 second and more than 30 second in some occasions. Not good enough for the money spent.
                          • surfboomerangS Offline
                            surfboomerang
                            I noticed that different sport modes have different intervals. Probably to save battery.
                            For example: if I select Windsurfing or Other as sports mode, I get a GPS point every second in performance mode. If I select a running sports mode I see a recording interval of a few (3 or 4) seconds. The gaps between are probably filled by their FusedTrack technology.
                            I think it would be nice to have an override option in the settings to set the recording interval for the activity, because different people have different needs but unfortunately this is not an option at the moment.
                            Suunto Vertical Titanium Solar
                            OnePlus Nord 4
                            freeheelerF 1 Reply Last reply Reply Quote 2
                              freeheeler @surfboomerang
                              @surfboomerang
                              the manual says fusedtrack will only (?) be active in running and trailrunning when endurance or ultra batterymode is selected.
                              you’re right, there should be a superperformance mode that actually records every 1sec for people that use it. For my sports it is good as it is, but I can imagine some people need it with higher precision
                              living sideways
                              • Dimitrios KanellopoulosD Online
                                Dimitrios Kanellopoulos Community Manager
                                Hi,
                                this is simple to solve. You are mostly static on the field and there is no GPS location update if you just move lets say 3m and then back. That is to avoid static.
                                Steps are not related to this. GPS and steps are decoupled.
                                Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                                freeheelerF 1 Reply Last reply Reply Quote 4
                                  freeheeler @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos
                                  because of this S9B does not do nervous recordings when I do a small pause without hitting the pause button, since the new FW update… hence it does not count extra distance that the user actually did not walk 👍
                                  for hiking, running, biking, skitouring etc this is perfect, but maybe not for footballers…
                                  living sideways
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                    Dimitrios Kanellopoulos Community Manager @freeheeler
                                    @TELE-HO correct my friend. Although as you said it depends on the “action” and distance from previous point for example. In short, I think, if you dont move out like 3-5m from that place that you are it wont record / increase the distance if the pace is low. If not it will.
                                    That is for Static detection
                                    • A Offline
                                      Alexbg
                                      Thanks a lot for the feedback.
                                      However still it seems unclear how Suunto Spartan Ultra and other brand watches tracked same amount of steps, but higher run distance.
                                      Is it something wrong with the software of Suunto 9 Baro?
                                      Is the GPS hardware/software of Suunto 9 worst than Spartan?
                                      • A Offline
                                        Alexbg
                                        That football tracking distance bug just doesn’t give a break. So I go deeper. Suunto App/Sports Tracker gives you a possibility to extract raw data from your watch in FIT (the former app) and in GPX format (the latter app). I found very useful the GPX data. It is very easy to analyze it. Simply open the GPX file with notepad and you see the following pattern for each GPS point:
                                        </trkpt>
                                        <trkpt lat=“42.68561” lon=“23.33532”>
                                        <ele>568.0</ele>
                                        <time>2019-11-24T15:24:27Z</time>
                                        <extensions>
                                        gpxtpx:TrackPointExtension
                                        gpxtpx:hr94</gpxtpx:hr>
                                        </gpxtpx:TrackPointExtension>
                                        </extensions>
                                        </trkpt>
                                        where: lat is Latitude; lon is Longitude; ele is Elevation; time is the time stamp of the GPS refresh point; hr is hart rate;
                                        As far as I read over the net FIT format gives you the possibility to record even more data.
                                        As the GPX file is XML it can be opened in Excel and read in much more user friendly way.
                                        In order to calculate the distance the watch and the apps get the latitude, longitude, (if they want to precise the elevation too) between two time stamps and using a formula calculate the distance.
                                        What I observe in the GPX file is that I have a GPS time stamp every second, BUT the GPS coordinates (latitude and longitude) are the same for a set of data and changes randomly.
                                        Puzzled with this I tried to measure the distance between each change of GPS. I do it on the web with free access Coordinate Distance Calculator. The first ten changes which I checked appeared after distance between to GPS points is exactly 10 meters.
                                        This means that to get an update of your GPS coordinates you need to move at least 10m, i.e. if you move 8m forwards and 8m backwards you will get 0 distance covered.
                                        Lets go back to football. If you play in a field with a size 44m long, 22m wide and you play as midfielder, than you can do countless amount of steps (measured by the accelerator) and negligible run distance.
                                        Now lets go to tennis (one of the 80 sport available on the Suunto 9 Baro). The tennis field split by half (for 1 player) is 12m long and 8m wide. Probably it is better to delete tennis as an option on the watch?!? And there are many other sports: Volleyball, Squash, Ice hockey, Handball and etc., and etc.
                                        Probably this explains the cut corners in sports like running and cycling.
                                        I think this needs a FIX!!! Probably much shorter distance for GPS coordinates refresh or at least a software option to do it if you want.
                                        I’m attaching my GPX file, but you can always check yours. Let me know your thoughts. Thanks.
                                        11_21_19 17_52.gpx
                                          Dimitrios Kanellopoulos Community Manager @Alexbg
                                          @Alexbg hi this is not correct approach to debug an issue. Gpx data are extrapolated / interpolated and are from another service.
                                          Also your watch uses fused distance and speed it doesn’t obey only to GPS. GPS is there to help only.
                                          Here is an activity with the latest fw showing back and forth 10m increments.
                                          https://app.suunto.com/move/dimitrioskanellopoulos/5da20b6b58e211b29b61bc01
                                          And another one.
                                          https://app.suunto.com/move/dimitrioskanellopoulos/5da1da0da6957b4b299b914a
                                          What I suspecting is that you use a sport mode without fused distance and that might be a bug if you used football.
                                          • ? Offline
                                            A Former User
                                            I agree with the 10 meter assessment. That is the same that I observed when looking at FIT files from my Suunto 9 (from running and trail running activities). It appears distance and coordinate updates usually come with at least 10 meter intervals, sometimes greater than that, but rarely less than 10 meters.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
