    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Spartan Sport WHR Baro - GPS Accuracy "OK" - fix rate
    Scheduled Pinned Locked Moved Suunto app and other software services
    31 Posts 3 Posters 3.8k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zadowZ Offline
      zadow
      Dears,
      For my hiking activities I am using power saving mode with GPS accuracy set to OK. I was always impressed how good is this accuracy. Well, it was so good that I started to be suspicious.
      According to manual:
      OK: ~ 60 sec fix rate with full power
      So, I extracted GPS file and checked times of GPS logs. I can see that the GPS is logged every second. OK, this I can understand that log rate is every second, as the BARO is reporting altitude. Then, I would expect that there will be 60 logs with same GPS coordinates. Nope. Cca up to 3 - 5 logs with same GPS coordinates.
      The most important thing is that battery drain for GPS accuracy “OK” was only slightly lower than for BEST/GOOD. It would definitely won’t last for 40 hours as declared. Yep, display was off and with low Color mode and no HR was recorded.
      So, could anyone explain, how the “OK” accuracy is really working?
      Description on this link is for sure not applied. At least, not on my watches.
      Thanks and have a nice day all!!!
      Suunto Race
      Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
      Suunto Smart Sensor
      Wahoo Tickr FIT
      Hammerhead Karoo 2
      Swim Ride Run Rest Repeat
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @zadow
        @zadow
        Did you use route navigation feature ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        • zadowZ Offline
          zadow
          Nope. No Navigation and Navigation screen set to OFF.
          Suunto Race
          Suunto Smart Sensor
          Wahoo Tickr FIT
          Hammerhead Karoo 2
            Dimitrios Kanellopoulos Community Manager
            Can I have the file to check this? preferably a FIT file 🙂
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            • zadowZ Offline
              zadow
              Sure. It’s on the way to you via messanger (;
              Suunto Race
              Suunto Smart Sensor
              Wahoo Tickr FIT
              Hammerhead Karoo 2
                Checked it you are right they are about 1-5s appart but many 1s appart
                  But I think the Spartans on Good record every 1s if I remember corerct
                  • sartoricS Offline
                    sartoric Moderator
                    Yes, but he say it was set to OK
                    I guess I’ve never tried “OK” just “GOOD” and it correctly records every 1s
                    Out of curiosity, is there any way to search moves (MC or SA) based on GPS setting ?
                    SVTS - 2.50.28
                    • zadowZ Offline
                      zadow
                      Correct, @sartoric . It was set to OK. I am using GOOD only on my long rides on bike. For hiking, I am always using OK.
                      Suunto Race
                      Suunto Smart Sensor
                      Wahoo Tickr FIT
                      Hammerhead Karoo 2
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                        Dimitrios Kanellopoulos Community Manager @zadow
                        @zadow oh!
                          Then I have to test it once. Anyone else up to the task?
                          • sartoricS Offline
                            sartoric Moderator
                            Gonna try a fake walking move 😄
                            SVTS - 2.50.28
                              Oh wait! wait wait wait.
                              The first 7-12 mins are on best to determine the fused alti!
                                Yes I crosschecked the file. Skip some samples at start and then its about 60s
                                • zadowZ Offline
                                  zadow
                                  Sorry guys, coming back a bit late. Trying to recovery a bit from my yesterday’s triathlon 🙂
                                  Well, maybe I am missing something or I am not reading the file correctly, but still I see GPS change every 3-5 seconds. I checked different parts of file.
                                  Could be the reason that I am reading GPS export from Strava? Fit file is in binary format.
                                  Anyway, still, if the GPS accuracy in OK mode, is really as good as I can see it in my hiking activities, then it is impressively good. 🙂
                                  I am going off for next two weeks, so no hurry on this topic. Thanks and enjoy the summer time!
                                  Suunto Race
                                  Suunto Smart Sensor
                                  Wahoo Tickr FIT
                                  Hammerhead Karoo 2
                                  sartoricS Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 1
                                  • sartoricS Offline
                                    @zadow
                                    Strava does its sh…magic 😁 with data during the import
                                    SVTS - 2.50.28
                                      @zadow It can be that reason. You can upload a fit file to https://fit2tcx.runalyze.com/temp/ to get a detailed decode for example.
                                        @zadow Or ask me for the data, or a way to show you how to do this on beta.quantified-self.io
                                        • zadowZ Offline
                                          zadow
                                          Dears,
                                          I am back after some time. Recovering after last triathlon race and enjoying time with my family. It’s a great summer, by the way 🙂
                                          I hope you all have also nice time, whatever you are doing 🙂
                                          However, I need to get back to this issue as I still think that there is a issue with GPS accuracy set to OK. I was on three days long hike. First day morning I set my SSWHR Baro as following:
                                          GPS accuracy - OK
                                          Low color mode - ON
                                          Display - OFF (after 10 sec)
                                          Navigation - OFF (completely, even the breadcrumb display was off)
                                          I was observing the GPS accuracy, which is not so important for me during hiking, but far more important - battery lifetime.
                                          Here are my issues:
                                          #1 - GPS accuracy - it’s just too good for OK mode. The fix is definitely not done each 60 seconds. According to my observation it is somewhere between 5 ~ 20 seconds. (yep, I am aware of first 15 minutes when FusedAlti should kick in).
                                          #2 - Battery drain - I guess this is connected with #1. According to Tech. specification, with GPS set to OK, the battery should last up to 40hrs. My hikes tooks approximately 6 ~ 7 hours. (Day #1 and day #2). The battery drain was from 60% ~ 70% percent, which is consumption about 10% per hour. Simple calculation tell us that with such consumption, battery would last about 10 hours. Hey, wait - 10 hours is expected at GPS set to BEST… 🤔
                                          So, I did some activities with different GPS setting to see battery consumption for each Power saving mode:
                                          BEST - cca 10% ~ 12% per hour
                                          Good - cca 5% ~ 7% per hour
                                          OK -cca cca 8% ~ 10% per hour
                                          That is pretty strange, isn’t it? Consumption for mode OK is worse than for Good… 😞
                                          I wanted to create a ticket for this but somehow could not find a link where to report it.
                                          For your reference, link to my activities:
                                          Hiking Day#1:
                                          https://app.suunto.com/move/zadow/5d505a3c17683a14e17386c8
                                          Hiking Day #2:
                                          https://app.suunto.com/move/zadow/5d516eef58e21162c5da60bc
                                          Hiking Day #3:
                                          https://app.suunto.com/move/zadow/5d5288bca6957bf53b9a7643
                                          P.S.
                                          Please do not advice me to go for S9 when I am so focused on battery life. I am not and I am pretty happy with my Sport Baro. It does everything what I need and it does it perfectly. Once the OK mode is solved, it’s still the best watches for all my needs. I just wanted to mention this upfront 🙂
                                          Suunto Race
                                          Suunto Smart Sensor
                                          Wahoo Tickr FIT
                                          Hammerhead Karoo 2
                                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                            @zadow Did you use navigation? What file is with the OK mode? Did you use any ETA custom fields?
                                            zadowZ 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
