    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Using Movescount web and Suunto app simultaneously
    Scheduled Pinned Locked Moved Suunto app and other software services
    46 Posts 16 Posters 5.2k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Is a question based on https://forum.suunto.com/topic/1240/parallel-use-of-movescount-suunto-app/ but this thread is closed, sorry.
      I can still use both simultaneously?
      I mainly used for the last months only SA.
      I already accepted the message that tell me that I would be disconnected from MC if I edit Sport Modes from SA.
      My idea is use MC web ONLY to sync the watch configuration via Suunto Link to my watch. For any other I will continue using the SA.
      This question is based on that I would like have a control on the altimeter profile of my Sport Modes and the watch.
      Or now I can´t have this control by the new fw of the last days?
      Thanks.
      • sartoricS Offline
        sartoric Moderator
        The original post was related to parallel use of MC APP an SA not MC WEB
        If you’ve already agreed to disconnect … well, you can use cable just for update and recharge.
        MC App and SA can still be used in parallel
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        • ? Offline
          A Former User
          @sartoric Edited, thank you!
          This mean that I can use both “apps” but can´t anymore use MC web, right?
          In case that I install the MC app, this app also not sync to MC web, only be useful to edit parameters on my watch, notifications, etc, until SA get all these features, right?
          MC app latest version is 1.5.11 or exist some beta link?
          Thanks again!
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Guest
            @flypg said in Using Movescount web and Suunto app simultaneously:
            Nope. MC App still works as normal.
            That’s the reason why many people here use it in “parallel mode”.
            This post is the one with install details : https://forum.suunto.com/topic/668/parallel-use-with-mc-app/5
            The one from your post it’s a sort of follow up
            SVTS - 2.50.28
            • ? Offline
              A Former User @sartoric
              @sartoric Thank you!
              mario_bM 1 Reply Last reply Reply Quote 0
              • mario_bM Offline
                mario_b @Guest
                @flypg I think the “big problem” problem is having to apps on your phone, both connected via Bluetooth to the watch. If both starting syncing at the same time, your watch can crash. I have both apps on the phone, but only one of them is connected via Bluetooth to the watch. So there is no possibility to double sync at the same time
                ? J 2 Replies Last reply Reply Quote 0
                • ? Offline
                  A Former User @mario_b
                  @mario_b Thanks for the information, I’ll try it on the weekend 🤞
                  • J Offline
                    johann.fuehrer Bronze Member @mario_b
                    @mario_b which one is the “active” one?
                    • mario_bM Offline
                      mario_b @johann.fuehrer
                      @johann-fuehrer because of i am new to suunto and wanna change settings on the ambit until get my basic setup. (which gps mode, which data fields on which sport-modes) i am connected to MC via BT. so i get the best of both worlds. a solid watch and background system that has worked for so many people so many years. and the ability to use the newest beta of SA.
                      • ? Offline
                        A Former User
                        Thanks to everyone! Done!. Both apps running and synching perfectly following this procedures and both using bluetooth.
                        To avoid this possible problem, the addition that I made to the procedures is set this limitations on these apps:
                        • Disallow background data usage
                        • Disallow background battery activity
                        I can do this because I not use Notifications on my watch, not need that the apps run continusly, and with this I can select when I like run the app and what app (MC or SA). In case that need that one of these apps it runs continuously, I can easily change this setting.
                        Now I can edit from MC web my sport mode settings again 😁 👏
                        After this I sync with the MC app to my watch.
                        Thanks @sartoric @mario_b again and @Dimitrios-Kanellopoulos for this procedures post. 👍
                        ? 1 Reply Last reply Reply Quote 3
                        • freeheelerF Offline
                          freeheeler
                          did anyone else notice a very slow MC web, too? It’s frequently showing an Error 504…
                          living sideways
                          malcywayM 1 Reply Last reply Reply Quote 0
                          • malcywayM Offline
                            malcyway @freeheeler
                            @TELE-HO I just noticed it about an hour ago. No 504 error but MCweb def slow. Thought it was just my wifi but that was not the case.
                            Suunto 9 Baro Black FW 2.10
                            IOS 13.2.3 IPhone 7 SA 1.14.1
                            Professional Sailor
                            freeheelerF 1 Reply Last reply Reply Quote 0
                              freeheeler @malcyway
                              @malcyway
                              I’m on glass fiber and from the other programms I use I know that the connection is as normal…
                              I’ve asked Dimitrios in another thread, waiting for his reply
                              living sideways
                              • Dimitrios KanellopoulosD Online
                                Dimitrios Kanellopoulos Community Manager
                                Hi this should be ok now
                                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                freeheelerF 1 Reply Last reply Reply Quote 1
                                  freeheeler @Dimitrios Kanellopoulos
                                  I don’t receive 504 errors anymore… but the speed is like in the middle age…
                                  living sideways
                                  • Saketo NemoS Offline
                                    Saketo Nemo Moderator
                                    I don’t find him slowed down. Of course, it has never been very fast…
                                      freeheeler @Saketo Nemo
                                      @Saketo-Nemo
                                      24 seconds from pressing enter until the start page is loaded…
                                      …sorry, “slow” is hard to quantify… 🙂
                                      living sideways
                                        wow ! 😮
                                        Not for me, not so slow. We are talking about few seconds, maybe four…
                                          @Saketo-Nemo
                                          almost 60 seconds to enter watch settings… same for editing sport modes…
                                          living sideways
                                          • mario_bM Offline
                                            mario_b
                                            Today my movescount (web) is also very slow. Solution: down bottom right of the page switch to the chinese server. movescount.cn is fast (you have to click on this this on it, only changing the adress links you back to .com. 😁 👌
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
