    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Watchface resetted
    Scheduled Pinned Locked Moved Suunto Race
    21 Posts 12 Posters 3.3k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Stefano M64S Offline
      Stefano M64 Silver Members
      A couple of hours ago I received a notification on my SR, as I pressed the crown to unlock the watch I found my watchface (stratum) resetted, both accent and complications. Never happened before …
      Suunto Vector . Vector HR . Core . Race & Race S
      Marius Jacobsen EggerudM 1 Reply Last reply Reply Quote 0
      • Marius Jacobsen EggerudM Offline
        Marius Jacobsen Eggerud Silver Members @Stefano M64
        @Stefano-M64 trhe same happened to me this morning with the vertikal week watch face.
        Suunto Ambit 3
        Suunto Spartan Ultra
        Suunto Race Ti
        S 1 Reply Last reply Reply Quote 0
        • ? Offline
          A Former User
          Same happened to me today. Hopefully it is a hint for some new watch faces arriving 🙂
          Stefano M64S 1 Reply Last reply Reply Quote 0
            Stefano M64 Silver Members @Guest
            Thanks!
            yes, that could be a possibility 😋
            • hombreuH Offline
              hombreu
              Using Bold bulletin watch face on a Race S here.
              This morning I I found the complications changed, and what is stranger, when I move my wrist to wake up the watch something appears that does not correspond to the time.
              I hadn’t seen the text style before either.
                Stefano M64 Silver Members @hombreu
                @hombreu said in Watchface resetted:
                did you tried to sync again with the app?
                hombreuH 1 Reply Last reply Reply Quote 0
                • S Offline
                  SergioB Bronze Member @Marius Jacobsen Eggerud
                  @Marius-Jacobsen-Eggerud same!
                  Suunto Race 1 and SuuntoApp on Android 13.
                  kriskusK 1 Reply Last reply Reply Quote -1
                  • kriskusK Offline
                    kriskus Bronze Member @SergioB
                    This was also mentioned here: https://forum.suunto.com/post/163913
                    • pavel.samokhaP Offline
                      pavel.samokha
                      Reset happened due to watchfaces updates, sorry for inconvenience.
                      Bold Bulletin issue - known, version rollbacked to previous one. If still happens to you then please sync the watch to app and restart the watch.
                      Opinions expressed are solely my own and do not express the views or opinions of my employer
                      1 Reply Last reply Reply Quote 6
                      • hombreuH Offline
                        hombreu @Stefano M64
                        @Stefano-M64
                        Yes, I did. I’ve also tried a soft reset and uninstalling and reinstalling the watchface.
                        It’s not particularly bothersome, I’m just struck by those numbers that don’t seem to correspond to anything, neither heart rate, nor time, nor available battery… (now it says 25 36)
                        • TieutieuT Offline
                          Tieutieu Platinum Member
                          What I experimented on both my SRs and my SV is a color reset of the vertical week watchface (my current one on both). Happened twice today, one time on each
                          Suunto’s devices at home :
                          Vertical titanium solar
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                          S9B titanium Ambassador edition, A3P, X6
                            pavel.samokha
                            Bold Bulletin was updated once again
                            • ? Offline
                              A Former User
                              Is it just me, or did the Ocean watch face get a bit misaligned (: separator)? I remember it used to look centered.
                              • D Offline
                                duffman19
                                @pavel-samokha Also, an issue with “Classic Analog” while using the “contrary” accent color, the second hand is white and disappears. It should be/was black.
                                Vertical Ti / S9PP Ti / S9P Ti
                                pavel.samokhaP 1 Reply Last reply Reply Quote 1
                                  pavel.samokha @duffman19
                                  @duffman19 I don’t think this one was updated, but could you make a photo of the issue?
                                  D 1 Reply Last reply Reply Quote 0
                                  • D Offline
                                    duffman19 @pavel.samokha
                                    @pavel-samokha Hard to document since it looks invisible, but the second hand is at the “2” position in the image below. Tried a reset and re-install of the watch face, but didn’t help. (I know it’s a Vertical, but posted here because this is where the discussion is.)
                                    pavel.samokhaP 1 Reply Last reply Reply Quote 0
                                      @duffman19 thanks, sorry for the issue.
                                      Version is reverted. If still happens to you then please sync the watch to app and restart the watch.
                                      D 1 Reply Last reply Reply Quote 2
                                      • D Offline
                                        @pavel-samokha Thank you. A fresh install of the watch face solved it for me.
                                        • sartoricS Offline
                                          sartoric Moderator
                                          @pavel-samokha
                                          Something happened today too, maybe it’s related to FW beta release?
                                          SVTS - 2.50.28
                                          SSSWHR BARO Amber - 2.8.32
                                          Samsung A5 2016 - Android 7.0
                                          Suunto App Android 6.11.12 beta
                                          M 1 Reply Last reply Reply Quote 2
                                          • M Offline
                                            M2Oskie @sartoric
                                            @sartoYepric Yep. Race S here. Second hand on Classic Analog when back from green to white - again. On the upside, I’m warming up to the Stratum face. 🙂
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
