    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Blood oxygen saturation values completely wrong and inaccurate.
    Scheduled Pinned Locked Moved Suunto Race
    22 Posts 10 Posters 5.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Max90PayneFPV
      Hello everyone !!
      I took some measurements with my nuvo race of the blood oxygen saturation value…
      All readings report absurd and inaccurate values!!
      Values like 70-80…I wouldn’t be here writing!!
      Comparison tests were carried out with a certified oximeter, Apple Watch 6 and Amazfit Trex 2…which all give me real and exact values!!
      I wear the race on my left wrist where I always put my other smartwatches too…
      Defective sensor? Can a calibration be done?
      A thousand thanks
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        Max90PayneFPV @Max90PayneFPV
        surfboomerangS GiPFELKiNDG 2 Replies Last reply Reply Quote 0
        • surfboomerangS Offline
          surfboomerang @Max90PayneFPV
          @Max90PayneFPV SpO2 has never worked for me either. Not with my S9P and not with the SV.
          That is, if it even measures. Most of the times I get a warning it could not measure it.
          The only time I get values is if I press my finger on the sensor 😄 Even then the values aren’t consistent.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          • Sebastian Wagner 0S Offline
            Sebastian Wagner 0
            at first i have got the same problem with my suunto race.
            then i wore my watch a bit away from the wrist joint, more towards the forearm (there is more flesh) there i get good readings for spO2. around the wrist it is too bony. hope that helps.
            t3c / ambit / spartan sport /spartan titanium ultra / race
            • GiPFELKiNDG Offline
              GiPFELKiND Silver Members @Max90PayneFPV
              @Max90PayneFPV Hey Bro 🤗 if you wear your watch everytime like this i think it is okay that you get false values. You have to put the sensor 2 fingers away from your wrist. Try it like in my Picture and hold your watch only with 2 fingers in Position.!
              2 fingers away from your wrist Look at the first picture
              Try it without fixing the Wristband and hold it in place – Look at the 2 Picture, press the watch soft on your skin. To much pressure also make false values.
              Then i get right values … Perhaps this Help you 🤗! Show the last Picture
              If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
              surfboomerangS 1 Reply Last reply Reply Quote 7
                surfboomerang @GiPFELKiND
                @GiPFELKiND moving the watch 2 fingers up and warming up the skin does help getting readings.
                I tried 3 times in a row without moving the watch or changing the pressure. The results were 73, 98 and 86. Not really the reliability I was hoping for…
                OnePlus Nord 4
                M Dante MclallaD 2 Replies Last reply Reply Quote 0
                • M Offline
                  maszop Bronze Member @surfboomerang
                  @surfboomerang It is best to place your hand on a table or other stable surface and do not make even the slightest movements.
                  • Dante MclallaD Offline
                    Dante Mclalla Bronze Member @surfboomerang
                    @surfboomerang
                    I think that the sensor used on SV and SR is bad and no firmware can mitigate its inaccuracy.
                    This proved to be the case with my SV which at the end I returned and I once again discovered that AW Ultra 2 e Epix Pro 2 have way better sensor than Suunto. It’s an unfortunate choice by Suunto which undermines the whole product which, apart from this, is a very good watch• If a sensor is faulty, all the measurements and health data are then unreliable.
                    I’m giving a last try to a Suunto Race arriving today and I will compare it with the Polar Vantage V3. The Polar still shows some inaccuracy. However, Polar uses a highly advanced sensor hardware - very different from Suunto crap sensor - which will be for sure improved with the next FWs.
                    ? M 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      A Former User @Dante Mclalla
                      @Dante-Mclalla said in Blood oxygen saturation values completely wrong and inaccurate.:
                      On what is this statement based? The fact that some users have uneven readings does not necessarily imply that the sensor is “bad.” I also happen to have erroneous readings, but for example on my wife’s wrist the readings are always correct (obviously compared to a oxymeter).
                      Dante MclallaD 1 Reply Last reply Reply Quote 0
                      • M Offline
                        maszop Bronze Member @Dante Mclalla
                        @Dante-Mclalla It works fine for me
                          Dante Mclalla Bronze Member @Guest
                          @robis Is based on my experience and looking at the results coming from Garmin Epix pro 2 and my Whoop.
                          Starting from today I will compare SR with Coros Pace 3 and Whoop and Polar Vantage V3 and let’s see how and if Suunto faces its competitors. Honestly, I have no great expectations…
                          By the way, from DCRainmaker “Now, remember I mentioned earlier in the review I only had two complaint areas? And that the first was slowness? Well, here’s the second – optical heart rate sensor accuracy. It’s bad. There’s no two ways to slice it.”
                          https://www.dcrainmaker.com/2023/11/suunto-race-amoled-in-depth-review.html
                          isaziI Dante MclallaD 2 Replies Last reply Reply Quote 0
                          • isaziI Offline
                            isazi Moderator @Dante Mclalla
                            @Dante-Mclalla for me both Vertical and Race match a chest strap in a large variety of workouts for 99% of the time.
                            Blog: isazi's home
                            • EgikaE Offline
                              Egika Platinum Member
                              this is about SpO2 measurement accuracy.
                              I do get consistently 97-99% readings if I trigger it during the day (watch worn as suggested, hand lying on table without movement).
                              If I enable the measurement during the night (which I usually don’t do as I live in Hamburg), I get 100% nightly maximums.
                              Seems to be good enough for me - while I have absolutely no use for this feature.
                              1 Reply Last reply Reply Quote 3
                                Dante Mclalla Bronze Member @Dante Mclalla
                                @Dante-Mclalla lets find out in the next days. I’d hope to get good results as I love Suunto watches.
                                Suunto (as well as Polar and Casio) should learn from Coros in terms of continuous release of FW update fixing issues and introducing new functions on both the latest and oldest releases. In few years, Coros took the lead in ultra marathon races and is second only to Garmin (5-7 years ago Suunto was a clear second behind Garmin). This means something…
                                  Dante Mclalla Bronze Member @isazi
                                  @isazi BO saturation depends on the sensor, if the sensor is inaccurate the same will be for BOxygen
                                  M EgikaE 2 Replies Last reply Reply Quote 0
                                  • M Offline
                                    Practice shows that this is not the case.
                                    • EgikaE Offline
                                      Egika Platinum Member @Dante Mclalla
                                      @Dante-Mclalla it depends on the sensor and the application of the sensor.
                                      The result cannot be better than each factor.
                                        Dante Mclalla Bronze Member @maszop
                                        @maszop Hope I’m wrong! I’ll see by myself in the next days: Suunto Race vs Coros P3 vs Whoop Vs Polar V3. I’ll keep the whoop and the most accurate watch
                                        EgikaE M 2 Replies Last reply Reply Quote 0
                                        • EgikaE Offline
                                          @Dante-Mclalla this makes sense, if it works best for you.
                                          Out of curiosity: What is your use case for a most accurate SPO2 measurement?
                                          • M Offline
                                            @Dante-Mclalla Watches, especially Suunto, have problems measuring heart rate during more intense activity. When at rest (blood oxygen measurement), it’s not that difficult, as long as the watch is fastened correctly, there are no tattoos, etc.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
