    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Import FIT activity
    Scheduled Pinned Locked Moved Suunto app and other software services
    38 Posts 16 Posters 11.9k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      Johann
      I would like to ask about the possibility of importing FIT activity to SA in the near future.
      I have seen some previous posts on this topic, but they are outdated and do not reflect the current situation.
      I am interested in knowing if this feature is on the roadmap or if there are any technical challenges that prevent it from being implemented.
      Thank you for your attention and response.
      Mff73M S 2 Replies Last reply Reply Quote 3
      • Mff73M Online
        Mff73 @Johann
        @Johann
        I am not from Suunto, so my comments are just my own knowledge and understanding 😉
        Do you mean, direct fit import in SuuntoApps (iOS or Android) ?
        FIT import is possible to your Suunto account, but only (now) through third party partners of Suunto (like Runalyze, or MyTourBook).
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        J 1 Reply Last reply Reply Quote 1
        • J Offline
          Johann @Mff73
          @Mff73 I have a fit file from FulGaz and I would like to import in SA.
          I know SyncMyTraks which is not good, couple of data are missing with this solution.
          I never heard about you both suggestions.
          I will try them.
          Any differences/recommandations between both ?
          Thanks 🙂
          Mff73M 1 Reply Last reply Reply Quote 0
          • Mff73M Online
            Mff73 @Johann
            @Johann
            Syncmytrack is even worse as it doesn’t use fit files and not connect to Suunto with proper security tokens (in fact it is using the “old” sports-tracker API (as far as i understand) and not upload fit files, but tcx or gpx files).
            I would recommand Runalyze to begin with (Mytourbook is a desktop application)
            Just one point, if everything seems to work well in Runalyze (saying file is properly uploaded), but nothing appears in SuuntoApp, then, most likely, your fit file is not “compliant” with Suunto’s fit “rules” (but nothing will tell you why 🙂 )
            Wife : S9PP
            J 1 Reply Last reply Reply Quote 0
            • J Offline
              Johann @Mff73
              @Mff73
              Yesterday I’ve tested Runalyze.
              And I’ve got the same result, everything is fine when imported to Runalyze, but when they import to Suunto, no Ascent and Descent values in SA 😞
              I asked them and they told me that is an issue on Suunto side…
              https://board.runalyze.com/d/59-sync-with-suunto
              So today I’m going to try Mytourbook…
              Disappointed so far 😢
              Mff73M Jeffrey TillackJ 2 Replies Last reply Reply Quote 0
              • S Offline
                Sascha Domres Bronze Member @Johann
                @Johann In addition to the app syncmyttacks, I still know RunGap… But I think the latter only works with iOS. In the past, you could upload .gpx files via the PC at Sports-tracker.com if logged in via the same access data… maybe worth a try…
                • pilleusP Offline
                  pilleus
                  The only solution which worked for me was QS, but it does not work nowadays. No idea why this happened.
                  All other third party apps or gpx import via Sportstracker does not sync ascent/descent and other data. The best sync is working with Garmin and the app health sync in android (ascent and descent are available in SA and even the elevation profile).
                  https://www.instagram.com/moves.are.life/
                  Suunto Vertical Black Lime
                  Suunto 9 Peak Pro Black
                  Suunto Spartan Ultra Stealth Titanium
                  Brad_OlwinB 1 Reply Last reply Reply Quote 1
                  • Mff73M Online
                    Mff73 @Johann
                    @Johann
                    I tried and fit import with runalyze.com is working as usual and I have ascent and descent because my fit files are containing these values.
                    Yes, ascent and descent must be present in the fit file, Suunto won’t calculate them.
                    If fuelgaz doesn’t export these values, you won’t get them just by importing. It will need outside reprocessing.
                    Wife : S9PP
                    J 2 Replies Last reply Reply Quote 1
                    • Brad_OlwinB Offline
                      Brad_Olwin Moderator @pilleus
                      @pilleus It does not work now because the developer stopped the development. That happened because no one was paying or contributing and the service was not free but maintained out of pocket for the developer and by a few donors.
                      Vector/T6c/Vertical 2 Ti
                      pilleusP 1 Reply Last reply Reply Quote 1
                      • J Offline
                        Johann @Mff73
                        @Mff73
                        So, the “issue” comes from FulGaz FIT file because they don’t add both values into their extraction 😞
                        Mff73M 1 Reply Last reply Reply Quote 1
                        • Mff73M Online
                          Mff73 @Johann
                          @Johann
                          probably. If you can share this fit file, one can check.
                          With Mytourbook, it is a little different, it is a desktop app, which can import your fit file, treat it (hopefully calculate ascent/descent), and then there is a recent feature to export this activity back to Suunto. It working quite “well”, as far as the activity doesn’t contain any pause (then there are some strange things happening in Suunto 🙂 root cause is still investigated).
                          Wife : S9PP
                          • pilleusP Offline
                            pilleus @Brad_Olwin
                            @Brad_Olwin said in Import FIT activity:
                            I paid via patreon over a year. But one day I was logged out and could not log in again. All data were lost. It was a bit disappointing. I like QS and it’s a great tool and outstanding web application. 👍
                            • J Offline
                              Johann @Mff73
                              @Mff73 It seems that runalyze.com does not sync “push” activities to SA, based on their reply.
                              For me, it is like SA is quite isolated 😖
                              pilleusP isaziI 2 Replies Last reply Reply Quote 1
                              • pilleusP Offline
                                pilleus @Johann
                                @Johann said in Import FIT activity:
                                SA = stand alone 🙃
                                • isaziI Offline
                                  isazi Moderator @Johann
                                  @Johann why they should, as they say they are not a syncing hub or app, they are a service on their own.
                                  Blog: isazi's home
                                  J 1 Reply Last reply Reply Quote 2
                                  • J Offline
                                    Johann @isazi
                                    @isazi
                                    I never say “They should”.
                                    My concern is to try to import my indoor bike activity within SA.
                                    @Mff73 kindly suggested me runalyze.com, and I only informed him that runalyze.com doesn’t delivery this service.
                                    @pilleus said in Import FIT activity:
                                    SA = stand alone
                                    isaziI Mff73M M 3 Replies Last reply Reply Quote 0
                                    • isaziI Offline
                                      @Johann runalyze does it, it does not do it automatically because doing it costs them money.
                                      Blog: isazi's home
                                      • Mff73M Online
                                        Mff73 @Johann
                                        @Johann
                                        I presumed that you knew how it works, but it seems not, sorry.
                                        I thought you needed to import a (one) fit file. It is possible, one by one, with runalyze.com, but not as syncing service.
                                        You need to link your runalyze.com account with Suunto, and then, as Isazi wrote, in runalyze.com, you have a feature to upload (one by one) an external fit file to Suunto.
                                        Manually and one by one, yes, automatically, no.
                                        Wife : S9PP
                                          @pilleus I pay as well, we were notified about the purge but it was a necessity as the non-payers vastly outnumbered the payers and there was no other way to reduce data storage to mitigate costs (my opinion from the little I know).
                                          • M Offline
                                            martin Bronze Member @Johann
                                            @Johann if you’re on IOs, you can try RunGap or Healthfit. RunGap is free to download and single activity tranfer uses but will need some sort of subscription if you want to automate, the other one is a paid app.
                                            It does not seem to me that any of these can directly connect to FulGaz (for the reason that FG does not seem to allow you to connect to much platforms) but if your activities are sent to Strava (or you are willing to setup an account to do that, it can stay private), you can most probably find a way to automate their retrieval and forward them to SA.
                                            W 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
