Routes onto watch
hi… spent enough hours trying, hopefully someone can help. Urgent as i need the route on watch by friday for a race.
Trying to get a route/gpx over to my S9 watch… I have tried several gpx routes. Opened up in Suunto App and saved with the ‘add to watch’ . Sync the App to watch and no routes are moved?
Tried a soft reset and a ton of other things and all i seem to be doing is wasting my time (i have successfully done this before as i have 6 routes on my watch that i now cannot delete!!).Any ideas, thanks. Andy.
@humpha
Have you tried to un-toggle / toggle the route again from the list ?
Sometimes the route is not sent to watch if you “toggle” it while creating itandroid or Ios ?
app version ?
hi… yep have tried it and tried again just now and sync’d. Still nothing uploaded to watch…
Android (samsung)
App is V 4.2.4I did mange to load some routes on last month which is why i am confused. The only thing i noticed was that the original gpx was 10MB file. But that never loaded into the App routes folder and i have closed everything down and on again since. Current gpx file is 59KB.
Try the beta. Look for the faq here
@humpha
Furthermore, you don’t need to sync to send the routes.
It’s automatically done when toggling it
thanks… so become a tester on the suunto app? doesnt sound like it will fix my issue by friday which is my problem.
@sartoric
thanks… i did think it did it automatically but was looking to see if i saw a number when syncing… routes is blank but i see number for my activities…
thanks guys…i have solved it… i tried one last thing and that was to uninstall Suunto App and re install i also did a soft reboot on watch…
The app then reloaded some old routes and i reloaded the gpx file onto Suunto app and toggled the Add to watch and now i have it on my S9 watch. Happy days.
Not ideal to have to uninstall but at least i have the route on my watch for the race (the reason for buying the watch in the first place).All the best
Andy.
@humpha said in Routes onto watch:
Usually you don’t need to
Maybe something was stuck from some unknown reason and maybe (I don’t remember well) there was a bug on routes management on that version.It could be an App cache issue too, so it could be enough to wipe the cache data instead of uninstall/install
